Since 2019 Bifrost's scratch cache and background processing just do not work.
- Play every frame selected.
- Both turned on in Bifrost options.
Any information would be great as I have a deadline tomorrow.
Hi @Anonymous
A quick test you can try is unloading and reloading all of the bifrost plugins to "refresh" them and make sure there are no issues.
If that doesn't help you can check out this article on scratch caches.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
