Bifrost Rendering
Bifrost Rendering
Message 1 of 10
Bifrost Rendering
I've only been using Maya for a few months but I thought I'd like to give the Bifrost Fluid Simulatior a try.  It worked and I loved the beautiful results I got from it.  However, when looking through the rendered images, I noticed several, "jump cuts."  Going from one frame to the next didn't match up several times and when I played the whole thing back it took a lot out of it.  Below I've attatched two frames demonstrating the "jump cuts."  If you need more info or have a solution please respond, any and all help is welcome.
Replies (9)
Message 2 of 10
FalconCrest
Try caching your simulation.
Message 3 of 10
And how would I go about doing that?
Message 5 of 10
I tried to create a cache but it keeps giving me an errror message.  I tried setting the frame range to both the start of the simulation (Frame 1) and the beginning of the time slider (Frame -100).  The error message mentioned something about a plug-in which I looked for but couldn't find anything.  It also said I must select bifrost containers (the pipe and the pool in this case) so I shift selected them all and tried again with the same result.  Thanks for your timely responses!
Message 6 of 10
FalconCrest
Can you paste the context of the error message ?
Message 7 of 10
I'm sorry, I feel like I'm asking for a lot, I'm really new at this so I'm gonna need you to dumb that down.
Message 8 of 10
I'm sorry, I'm reallly new at this and am going to have to ask you to dumb that down for me. Thanks again for your help!
Message 9 of 10
J450NP13
It is telling you what to do right in the error message. Bifrost is the plug-in it is talking about.
Also..you are giving simulation a try....what you see in your viewport is not what you will render out.  These kind s of simulations are expensive and tax everything involved.  When rendered there will not be any "jump cuts".
Message 10 of 10
pshwayka
The bifrost container is that box that is around your bifrost emitter. (See below.) You need to have it selected before you attempt to make your bifrost cache.
