Hi
Bevel tool keeps changing the shape of my object
So above is what I am trying to make.
This is the one I have made so far, and selected edges to apply bevel via CTRL + B.
This is how it turns out; the middle edge somehow gets pulled into center and forms a zig zag shape
whats even goofier is when I press Z to go back and cancel Bevel, the shape still stays zig zag
Why is this happening and how can I fix this??
Thank you in advance.
Sometimes the tools start to misbehave if there's construction history present. Deleting it usually helps.
I just made similar shape (CreatePolygon> MultiSplit> Extrude> Bevel) and tested, worked fine. My wild guess is, you could have made your profile from the polyCube with 16 y-divisions.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
Thank you again and I do appreciate your help ![]()
but frustratingly even after deleting history its having the same issue
Indeed it was polycube w/ 16 subdiv. I started over to remake it and this time it worked out fine.
Oh wow almost 4 years later and I ran into the same issue with the tutorial. It warped in a different spot but redoing the leg in 16 subdivisions worked for me as well, thx!
