Batch import obj/fbx?
I was wondering if there is a script or a way in maya to batch import meshes?
Thanks!
Replies (23)
Roland.Reyer
I tried to drag&drop a bunch of FBX files from the Windows explorer into the Maya 2018 window and it imported all of them.
Didn't test obj though.
Okay nice! I will see I update from 2016 to 2018 so I can try it out. If not is there any good other way for maya 2016?
sean.heasley
Hi @Anonymous and welcome to the community!
I just tested @Roland.Reyer's method of drag/dropping into Maya 2016 and I used OBJ instead of FBX and it worked fine!
Let me know if it works for you!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Anonymous
I'm just checking in to see if you need more help with this. Did you get a chance to try the steps @Roland.Reyer provided? They worked for me and I just wanted to see if you're still having trouble with it?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi again,
Unfortunately I can't upgrade Maya at this point. I tried drag and drop for FBX in maya 2016 which works fine. The reason I'm looking for a batch import is for the case when I need to import multiple meshes. Let's say I need to import 200 fbx meshes into Maya how would I do that efficiently? In another 3D software, MODO for example, I would simply shift select 200 meshes in the explorer import window and the program will go through and import all of them in an instant.
mspeer
Hi!
"I tried drag and drop for FBX in maya 2016 which works fine"
So what is the problem if it works fine?
"Let's say I need to import 200 fbx meshes into Maya how would I do that efficiently?"
Drag'n Drop 200 files into Maya at once (you know how to select multiple files?), or write a script that does this for you.
Edit:
Use the File Explorer of your OS and not the Maya Open/Import Dialog for Drag'n Drop.
I should have been more specific with this sentence "I tried drag and drop for FBX in maya 2016 which works fine". Drag and drop works fine for one mesh and I would like to import multiple meshes at once efficiently. Drag and dropping more than one FBX mesh will open importer for the first one and for the rest show an error dialog "Warning: An import FBX dialog is already open". Maybe if there was a way to suppress the import window the drag and drop would work for multiple meshes at once.
I have limited experience in scripting for Maya but if that is the only way to import more than one FBX mesh at once I will learn.
mspeer
Hi!
Please describe in detail (step by step) what you do and post a screenshot.
Here (Maya 2016.5 - 2018 on windows) it's just:
1. Select multiple FBX files in Windows Explorer
2. Drag into Maya main Viewport
3. Release
That's it, no dialogs or anything other, it can't be more efficient.
description in the image attached:
mspeer
Hi!
Thanks for the info.
Maybe this is a limitation of Maya 2016. (i don't have Maya 2016 installed, so i can't test this).
You could try a reset of your preferences to make sure there is nothing wrong set.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
The only other options would be to install a higher SP or upgrade Maya.
sean.heasley
Hi @Anonymous
I'm pretty surprised you're seeing this issue. I just tried drag and dropping 20 objs into Maya 2016 and 2016.5 and it worked as intended.
You may want to try the steps @mspeer provided and see if that helps resolve the issue!
Let me know if anything changes!
Thank you Mspeer and Sean! Preference reset made me able to drag and drop multiple FBX files into Maya. This will save a lot of time when dealing with large number of FBX's!
sean.heasley
Hi @Anonymous
Great and I'm glad it worked for you! Thanks as well for explaining what helped you and marking the solutions!
askinner6CDVL
This doesn't work for me in Maya 2017, 2018 or 2019 even with preferences reset. It only adds the first object and ignores everything else.
askinner6CDVL
For anyone else having this problem instead of simply deleting all your prefs, the actual solution that worked for me was to Edit preset for importing fbx. Change file content to add (if you dont care about animation). Close that. Then go to namespace options and turn off use namespaces and resolve clashing nodes with the filename. That will stop it getting hung up after importing the first object.
adenne
This didnt work for me, it is something within prefs, would be nice if Autodesk could actually delve into a little more than just defaulting to 'delete prefs'   "solution".  Which part of prefs gets corrupted?
Roland.Reyer
Insead of deleting the prefs you could just rename them and see if the prefs are really a problem. Just rename the folder "2019" (or your version) and restart Maya.
In case I really have to delete my prefs I have a workflow of copying my hotkeys, marking menus, shelves, to new the prefs.
However, I agree with you that corrupting the prefs is a bad habbit and should be fixed.
The-Digital-Shaman
Doesn't work for me. I got error that dialog window is already opened.
After re-clicking the error message and accepting import in the window I got only 1 asset in my scene.
The-Digital-Shaman
It doesnt.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
