Bad bug at Rendering an Animation?
I made an animation by a python script (see attachment)
But when rendering the whole animation from the beginning, one gets the that wrong result:
(There sould only be one text "Keine Tippfehler mehr")
Batch Rendered
But when I start rendering from an later frame, one gets the correct result (Starting at the first frame, where this animation starts):
Correct rendering
Did I made any fault?
Or is this a bug?
Unfortunately one can not start a rendering by a script. Or is there a possibility?
Thanks in advance!
Matthias
PS. I am using the renderer mental ray.
saihtam
Does this happen in Maya as well or only when you render?
- Mathias
@saihtamIn Maya everything is correct. This only happen when performing an batch rendering.
