Backface culling broken - Maya 2016
arcon76
arcon76
The "Backface Culling" checkbox in viewport shading menu doesn't worked on textured objects in the viewport, it only works in "5" shaded mode.
I'm pretty shocked this has made it past QA... it needs to be addressed in the next patch asap.  This worked fine in previous Maya versions.
pshwayka
Seems to be working for me....here are above and below shots of a half-sphere with the checkerboard texture applied.
arcon76
Doesn't work for me - if I apply a surface shader with a transparent file texture to a plane, and then turn on BC, I can still see both sides of the textured plane.  However if I press 5 for shaded mode the plane will cull correctly.
pshwayka
Okay, I see what you mean. Go into your Viewport 2.0 settings and change the transparency algorithm to Weighted Average.
arcon76
Thanks that fixed it... there are quite a few default settings like this which have really obscure fixes..
pshwayka
Yup...it took some trial and error to figure that one out. Glad it's working for you.
Smiley Happy
