Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Autodesk Maya 2022 Crashes on startup
1 REPLY 1
Soliye
333 Views, 1 Reply
I've been using this student version of Maya without any issue for the past few months. Today I restarted my computer and, after that, Maya wouldn't open any file. Opening a new scene does not work either. It shows the loading screen and then a Fatal Error pops up ~5 seconds after. I can't seem to figure out what exactly is causing this issue, so here's the MayaCrashLog:
Maya Crash Report
Exception code: E06D7363:
Fault address: 3B5E4FD9 in C:\Windows\System32\KERNELBASE.dll
0001:00033FD9 Logical offset (see .map file for location)
Weirdly enough, Window's Event Viewer did not log any crash.
Things I've tried:
  • Restarting my computer.
  • Downloading newer & older GPU driver.
  • Adding "MAYA_DISABLE_OPENCL" value "1" on window's environment variable &/or maya's .env file.
I'll have to try uninstalling/reinstalling, but wanted to see if anyone may have a solution. I've seen similar problems on the forum, but nothing with this specific error.
Computer Information:
Windows 10 - 64 bit
Intel(R) Core(TM) i7-7700 CPU @ 3.60 GHz
16.0 GB RAM
Used (GPU): NVIDIA GeForce GTX 1070
1 REPLY 1
Christoph_Schaedl
in reply to: Soliye
Try to deleted your prefs folder?
https://linktr.ee/cg_oglu
