Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Auto keying not setting frames at all
5 REPLIES 5
lebert823
6493 Views, 5 Replies
I was just about to finally start animating in Maya 2016 and i clicked the auto keying button and moved my character. When i moved him i looked and no keyframe was set. I made sure it was on, turned it off and on again and still no keyframes. Any reason why it shouldn't work? Thanks everyone in advance!
5 REPLIES 5
Roland.Reyer
in reply to: lebert823
Auto Keyframe will only keyframe those channels that already have a keyframe *OR* the channels in the current character set.
You need to either set an initial keyframe for the channels that you want to animate *OR* define and set a "Character Set" (Animate->Key->Create Character Set).
mspeer
Hi!
Auto key only works for channels/attributes that already have at least one key.
lebert823
I just set key frame in all channels and everything is working. Thank you both!
benjaminc404
I have set a key for every channel, still not working.
Restarted maya, not working still.
Reset preferences, STILL not setting any keys.
I don't know what I need to do to fix it. 😞
eweissU28PA
Same results here. Keys set in desired channels but auto key is not updating all channels correctly. Maya V2022.4
