Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
audio problem
17 REPLIES 17
Message 1 of 18
34566 Views, 17 Replies
audio problem
hi. . .when i import audio (wav) in maya 2014 nothing gets  loaded in the time slider, it shows no sounds available..how do i slove this ???
17 REPLIES 17
Message 2 of 18
pshwayka
Right-click on your timeline, and make sure your wav file is selected under the "Sound" settings.
Message 3 of 18
in reply to: pshwayka
It says no sounds available
Message 4 of 18
pshwayka
Does the wav file play outside of Maya? Also, have you tried other wav files in Maya?
Message 5 of 18
Yes it plays outside. . and no other wav file is played in Maya. . . and
I'm using student version . . is that a reason for this ??
Message 6 of 18
pshwayka
No...the student version does everthing the commercial version will do. The good news is, I think i have a solution. (I was able to reproduce your issue.)
You need to convert your sound file to a Microsoft signed 16 bit PCM wav format. If you don't have a program that will do this, you can download Audacity at www.audacityteam.org. (It's free.)
Open your file with Audacity, then click File->Export Audio and choose the format I mentioned above. The newly saved file should now load into Maya.
Message 7 of 18
it worked . . thank u .
Message 8 of 18
not working for me 😞
Message 9 of 18
Try deleting the audio first, then re-importing:
Choose Edit > Delete All by Type > Sounds to delete all audio files in the scene (if you only have one sound file).
Then import the new sound again.  For some reason I got stuck here too, and following the above worked.
Message 10 of 18
Thanks so much for this - you are a gem!
Message 11 of 18
nacho.grodek
Hi, I followed every step you detailed and I got to import the audio and actually see it in the time slider, but now whenever I press Play I can't listen to anything. Got any idea what may be the issue?
Message 12 of 18
nacho.grodek
in reply to: nacho.grodek
Solved, I just had to press Playback Speed -> Real time
Message 13 of 18
sflipse
thank you that worked! 🙂 how do you get it to work every time though? bc after I played it went back to the "Play Every Frame" setting
Message 14 of 18
sflipse
also just wondering if the Audio Node exports the sound too? Or is it just used as a visual aid within maya, but then you layer your sound later like in Premiere Pro. Asking bc I opened my files into Premiere and it was just visuals no sound.
Message 15 of 18
Tried doing all the given steps.. But it is still not coming for me... I'm not able to even view it in Time slider... I'm even not able to view it in in the sound option after doing a right click in time slider
Message 16 of 18
wang.shihtung
Sorry to necro this post, but I also followed steps above and nothing works.
Turns out the problem is my sound file's name "01.wav"
Maya somehow can't recognize number-only file name. I changed  "01.wav" to "sound1.wav" and solved the problem.
Message 17 of 18
dahernandezb
You can also do it with adobe audition, when you are exporting the file there is a way to change it to 16 bit PCM wav
Message 18 of 18
rweirTCJ7P
I just had a similar problem - and discovered that my file name, "15.wav" was invalid.  As soon as I renamed the file as "fifteen.wav" it worked.
