Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Arnold Transparency Issue in Viewport
3 REPLIES 3
ktheorin1
2991 Views, 3 Replies
As you can see in the picture, Arnold is rendering the alpha I put on this texture correctly, but won't show the transparency in the viewport. Is there a way to fix this? When I use a standard material with an alpha, Arnold won't render it, but it will show correctly in the viewport.
3 REPLIES 3
parabhdeep
in reply to: ktheorin1
Hi There,
Go to Renderer, Viewport 2.0,Performance, transparency algorithm, Select the option ALPHA CUT.
Hope you got what you want, you can also save this to your default setting.
greenscience
in reply to: parabhdeep
The screenshot you attached saved me a lot of headache. Thank you so much!!
EarthHobbit
On top of it I had to select Transparent Shadows in the same Renderer window
