Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Arnold Rendering ncloth Issues
5 REPLIES 5
2104 Views, 5 Replies
I've been having an issue with Arnold lately that I can't seem to figure out. I have an ai standard material with a transparent background, I have loaded in the alpha channel and everything seems to render out fine in Arnold until I put ncloth on the object, this seems to be cancelling out the alpha channel somehow and causing the object to render with a black background.
Any ideas?
5 REPLIES 5
mspeer
Hi!
nClothShape seems to override setting in the originalShape settings, so your Arnold settings in the originalShape are ignored and "Opaque" is enabled and can't be disabled in nClothShape.
A workaround could be to use 2 shapes, one for simulation and one for rendering or use an other renderer.
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
Stephen.Blair
After you convert to nCloth, you have to set the Arnold properties (like Opaque) on the outputCloth mesh
// Stephen Blair
// Arnold Renderer Support
I thought I had tried that but I tried it again and it worked, thanks!
mspeer
in reply to: Stephen.Blair
Hi!
Thanks, i was just looking at the nClothShape and missed outputCloth, so yes, using the attributes in outputCloth works.
mspeer
Hi!
Please mark the answer from @Stephen.Blair as solution.
Technology Administrators
