Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Arnold render window will resize itself and jumps across screens
7 REPLIES 7
Message 1 of 8
johnstifter
365 Views, 7 Replies
After I've situated all my windows when I click render, the render window will resize itself and move across the screen strewn out between two screens .. and that causes a lag.  Is there any way we can lock the renderer window keep it from resizing and moving every time because it becomes problematic on multiple levels.
Regards, John
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
slhodak
in reply to: johnstifter
Having this issue too - I position the window carefully in a corner so it won't overlap other important windows, but when I start rendering, the window widens up and covers up the windows next to it (which is usually my main Maya window.)
Message 3 of 8
damaggio
in reply to: slhodak
No versions? no OS?
Message 4 of 8
slhodak
Sorry, good points. 2023.3, Windows 10.
Message 5 of 8
hagen.deloss
Hi @johnstifter
That sounds frustrating! @Stephen.Blair is this something you have encountered before?
I'm not seeing any specific Arnold UI lock settings but i could be off base! I would always recommend, if you aren't on the latest version of Arnold (MtoA 5.3.3.1), to download that and see if the issue persists.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 6 of 8
slhodak
Hi @hagen.deloss ! I have what I hope is some more helpful detail for you. It happens when IPR is watching for changes, and I change a shader in Hypershade by connecting a new node to one of the shader's ports, triggering a rerender and also resizing the window.
Message 7 of 8
slhodak
Well, not every time apparently...
Message 8 of 8
johnstifter
in reply to: hagen.deloss
Thanks i'll give it a try. a bit off subject where can I go with a 88,000 lined sketch based modeling tool script ? Also I'm am looking for a place to see what people are doing with copilot and GPT4.
