Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
ARNOLD RENDER HAS DISAPPEARED!!!
8 REPLIES 8
Message 1 of 9
16313 Views, 8 Replies
What the f@ck!
// Warning: file: C:/Program Files/Autodesk/Maya2017/scripts/others/supportRenderers.mel line 64: The renderer "arnold" used by this scene, is not currently available. The "mayaSoftware" renderer will be used instead.
The "arnold" tab IS COMPLETELY GONE!!!!!
8 REPLIES 8
Message 2 of 9
Stephen.Blair
Open the Plug-in Manager, find mtoa.mll, and select the Loaded and Auto Load check boxes.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
in reply to: Stephen.Blair
Thank you. Why did this happen!?!? I want to know what caused this and if it is going to be an ongoing theme with Maya. I noticed it right after a crash and restart of Maya.
Message 4 of 9
Stephen.Blair
Hi
It hasn't happened to me much (just once that I remember) and it doesn't come up in my Solid Angle support queue, so I haven't investigated why this happens.
But here's what I think:
The plugin auto-load preferences are stored in your user preferences (prefs/pluginPrefs.mel).
When Maya crashed, either just the MtoA auto-load preference was reset and then written to that file, or the whole pluginPrefs.mel was reset to the default.
This is nothing new:
http://mayafeedback.autodesk.com/forums/160518-small-annoying-things-to-fix-in-maya-forum/suggestion...
Stephen
Solid Angle Support
// Stephen Blair
Message 5 of 9
Raverro
I've checked the check boxes in the plug-in manager, the "auto load" will hold a check mark but the "loaded" box wont keep a check mark in the box (it refuses to be selected), I even completely reinstalled Maya 2017 and still no Arnald... Please help...
Message 6 of 9
Stephen.Blair
in reply to: Raverro
It's not necessary to reinstall Maya. Just install MtoA. You can download the installer from solidangle.com
If MtoA won't load, check the script history for errors.
Then go here:
https://arnoldsupport.com/2016/11/08/mtoa-unable-to-dynamically-load-mtoa-mll-the-specified-module-c...
// Stephen Blair
Message 7 of 9
Raverro
Fixed it... I had to reinstall Arnold from the Solidangle website...
 https://www.solidangle.com/arnold/download
yay me! 🙂
Message 8 of 9
Raverro
Thanks for the quick response... you're a great help!!! BIGGEST THANKS!! 🙂
Raverro
Message 9 of 9
abars51099
But those boxes ARE checked & I still don't see Arnold
