Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Arnold render freezes with GPU but not CPU renders
15 REPLIES 15
Message 1 of 16
coopercubbage
8648 Views, 15 Replies
I've been scratching my head over this one for a week now.  I've tried this one two different computers and both will freeze with rendering with a GPU, but work perfectly fine with CPU.  I've cleaned the scene, reinstalled drivers (even trying several different iterations), reinstalled maya, reinstalled arnold and even reinstalled the entire computer fresh as well.  I've cleared the GPU cache and re populated it as well.
Are there specific settings that are needed with GPU?
15 REPLIES 15
Message 2 of 16
diana.yr
in reply to: coopercubbage
Hi @coopercubbage
Sorry that you are having trouble with the freezing. You can view the hardware lists here to ensure you have the proper settings.
Here is another similar thread that may help you as well. Please let us know if you're still needing assistance!
Diana Rouge
Social Media Specialist
Message 3 of 16
You need the required minimum driver version: https://docs.arnoldrenderer.com/x/i4QsBQ
(that page has the required driver for the latest MtoA)
There's no scene-specific settings required (to avoid crashing or freezing).
Do you have an Arnold log for a GPU render?
Does this happen with any scene, or just that scene?
// Stephen Blair
// Arnold Renderer Support
Message 4 of 16
I have RTX cards that are on the supported list and I've tried both 441.28 and the 441.60 drivers, there is no difference.
There is no log file that gets generated.  I turn on logging in the render settings and when I hit render, it has only the blue screen which will sit there indefinitely.  It will not render anything and it will not write anything to the log file.  I tried turning on full debugging though and I did get an error before it crashed:
ERROR | [gpu] an error happened during rendering : Unknown error (Details: Function "_rtContextLaunch2D" caught exception: Encountered a CUDA error: cudaDriver().CuEventSynchronize( m_event ) returned (700): Illegal address)
ERROR | signal caught: error E06D7363
It's only this scene that it is happening to.  It used to work within this scene, but something recently must have broken it because now it may render a frame or two, but usually it crashes on the first frame.
I did check the other thread, but I am not overclocking anything in this computer which was the solution in that thread.
Message 5 of 16
If you set the Arnold verbosity level to at least Info (Render Settings > Diagnostics), the log will be in the Maya Output Window (on Windows). If you are on Linux, then that output would go to the terminal window where you started Maya.
You can also send the log to a file.
The log header will shows us system details, like what OS, what card, what driver. And later in the log, how much memory is available on the card, and what's in the scene.
If we don't see anything problematic in the log, and it really is specific to this scene, then could we seen the scene?
// Stephen Blair
Message 6 of 16
Sorry for the delay!  Here is the log sent to info, ending in the error.  It rendered 39 frames in the sequence before it errored out.  Sometimes it happens on the first, sometimes on the fiftieth.  I've also attached the project file.
Thanks!
00:00:00  7729MB         | log started Sat Jan 11 10:20:20 2020
00:00:00  7730MB         | Arnold 6.0.1.0 [25372a4c] windows icc-17.0.2 oiio-2.1.4 osl-1.11.0 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.5.0 2019/12/04 07:47:29
00:00:00  7731MB         | host application: MtoA 4.0.1 a9b3c841 (master) Maya 2020
00:00:00  7732MB         | running on DESKTOP-NCJ2RN0, pid=8804
00:00:00  7732MB         |  2 x Intel(R) Xeon(R) Gold 5222 CPU @ 3.80GHz (8 cores, 16 logical) with 130767MB
00:00:00  7733MB         |  NVIDIA driver version 441.66 (Optix 60600)
00:00:00  7734MB         |  GPU 0: Quadro P5000 @ 1733MHz (compute 6.1) with 16384MB (13803MB available) (NVLink:0)
00:00:00  7734MB         |  GPU 1: Quadro P5000 @ 1733MHz (compute 6.1) with 16384MB (15190MB available) (NVLink:0)
00:00:00  7735MB         |  GPU 2: Quadro P4000 @ 1480MHz (compute 6.1) with 8192MB (7333MB available) (NVLink:0)
00:00:00  7735MB         |
00:00:00  7736MB         |  soft limit for open files raised from 2048 to 2048
00:00:00  7736MB         |
00:00:00  7729MB         | loading plugins from C:/Program Files/Autodesk/Arnold/maya2020/shaders ...
00:00:00  7730MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderDiffuseColorAdapter uses Arnold 6.0.1.0
00:00:00  7731MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderSpecularWeightAdapter uses Arnold 6.0.1.0
00:00:00  7731MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderSpecularGlossAdapter uses Arnold 6.0.1.0
00:00:00  7732MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderTransmissionWeightAdapter uses Arnold 6.0.1.0
00:00:00  7733MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderTransmissionSpreadAdapter uses Arnold 6.0.1.0
00:00:00  7733MB         |  lookdevkit_shaders.dll: ldkFloatConstant uses Arnold 6.0.1.0
00:00:00  7734MB         |  lookdevkit_shaders.dll: ldkFloatComposite uses Arnold 6.0.1.0
00:00:00  7734MB         |  lookdevkit_shaders.dll: ldkFloatCondition uses Arnold 6.0.1.0
00:00:00  7729MB         |  lookdevkit_shaders.dll: ldkFloatCorrect uses Arnold 6.0.1.0
00:00:00  7730MB         |  lookdevkit_shaders.dll: ldkFloatLogic uses Arnold 6.0.1.0
00:00:00  7731MB         |  lookdevkit_shaders.dll: ldkFloatMask uses Arnold 6.0.1.0
00:00:00  7732MB         |  lookdevkit_shaders.dll: ldkFloatMath uses Arnold 6.0.1.0
00:00:00  7732MB         |  lookdevkit_shaders.dll: ldkColorComposite uses Arnold 6.0.1.0
00:00:00  7733MB         |  lookdevkit_shaders.dll: ldkColorCondition uses Arnold 6.0.1.0
00:00:00  7733MB         |  lookdevkit_shaders.dll: ldkColorConstant uses Arnold 6.0.1.0
00:00:00  7734MB         |  lookdevkit_shaders.dll: ldkColorCorrect uses Arnold 6.0.1.0
00:00:00  7735MB         |  lookdevkit_shaders.dll: ldkColorLogic uses Arnold 6.0.1.0
00:00:00  7735MB         |  lookdevkit_shaders.dll: ldkColorMask uses Arnold 6.0.1.0
00:00:00  7736MB         |  lookdevkit_shaders.dll: ldkColorMath uses Arnold 6.0.1.0
00:00:00  7736MB         |  lookdevkit_shaders.dll: ldkChannels uses Arnold 6.0.1.0
00:00:00  7729MB         |  lookdevkit_shaders.dll: ldkPremultiply uses Arnold 6.0.1.0
00:00:00  7730MB         |  lookdevkit_shaders.dll: ldkSimplexNoise uses Arnold 6.0.1.0
00:00:00  7731MB         |  mtoa_shaders.dll: MayaMultiplyDivide uses Arnold 6.0.1.0
00:00:00  7731MB         |  mtoa_shaders.dll: MayaClamp uses Arnold 6.0.1.0
00:00:00  7732MB         |  mtoa_shaders.dll: MayaGammaCorrect uses Arnold 6.0.1.0
00:00:00  7732MB         |  mtoa_shaders.dll: MayaCondition uses Arnold 6.0.1.0
00:00:00  7733MB         |  mtoa_shaders.dll: MayaReverse uses Arnold 6.0.1.0
00:00:00  7733MB         |  mtoa_shaders.dll: MayaBlendColors uses Arnold 6.0.1.0
00:00:00  7734MB         |  mtoa_shaders.dll: MayaSamplerInfo1D uses Arnold 6.0.1.0
00:00:00  7734MB         |  mtoa_shaders.dll: MayaSamplerInfo2D uses Arnold 6.0.1.0
00:00:00  7735MB         |  mtoa_shaders.dll: MayaPlusMinusAverage1D uses Arnold 6.0.1.0
00:00:00  7730MB         |  mtoa_shaders.dll: MayaPlusMinusAverage2D uses Arnold 6.0.1.0
00:00:00  7731MB         |  mtoa_shaders.dll: MayaPlusMinusAverage3D uses Arnold 6.0.1.0
00:00:00  7732MB         |  mtoa_shaders.dll: MayaRemapValueToValue uses Arnold 6.0.1.0
00:00:00  7733MB         |  mtoa_shaders.dll: MayaRemapValueToColor uses Arnold 6.0.1.0
00:00:00  7733MB         |  mtoa_shaders.dll: MayaRemapColor uses Arnold 6.0.1.0
00:00:00  7734MB         |  mtoa_shaders.dll: MayaFile uses Arnold 6.0.1.0
00:00:00  7735MB         |  mtoa_shaders.dll: MayaPlace2DTexture uses Arnold 6.0.1.0
00:00:00  7736MB         |  mtoa_shaders.dll: MayaRamp uses Arnold 6.0.1.0
00:00:00  7736MB         |  mtoa_shaders.dll: MayaProjection uses Arnold 6.0.1.0
00:00:00  7737MB         |  mtoa_shaders.dll: MayaChecker uses Arnold 6.0.1.0
00:00:00  7738MB         |  mtoa_shaders.dll: MayaBulge uses Arnold 6.0.1.0
00:00:00  7738MB         |  mtoa_shaders.dll: MayaCloth uses Arnold 6.0.1.0
00:00:00  7739MB         |  mtoa_shaders.dll: MayaGrid uses Arnold 6.0.1.0
00:00:00  7730MB         |  mtoa_shaders.dll: MayaFractal uses Arnold 6.0.1.0
00:00:00  7731MB         |  mtoa_shaders.dll: MayaNoise uses Arnold 6.0.1.0
00:00:00  7732MB         |  mtoa_shaders.dll: MayaPlace3DTexture uses Arnold 6.0.1.0
00:00:00  7732MB         |  mtoa_shaders.dll: MayaRgbToHsv uses Arnold 6.0.1.0
00:00:00  7733MB         |  mtoa_shaders.dll: MayaHsvToRgb uses Arnold 6.0.1.0
00:00:00  7734MB         |  mtoa_shaders.dll: MayaLuminance uses Arnold 6.0.1.0
00:00:00  7735MB         |  mtoa_shaders.dll: MayaCloud uses Arnold 6.0.1.0
00:00:00  7736MB         |  mtoa_shaders.dll: MayaCloudAlpha uses Arnold 6.0.1.0
00:00:00  7737MB         |  mtoa_shaders.dll: MayaSnow uses Arnold 6.0.1.0
00:00:00  7738MB         |  mtoa_shaders.dll: MayaContrast uses Arnold 6.0.1.0
00:00:00  7739MB         |  mtoa_shaders.dll: MayaLayeredTexture uses Arnold 6.0.1.0
00:00:00  7740MB         |  mtoa_shaders.dll: MayaSolidFractal uses Arnold 6.0.1.0
00:00:00  7730MB         |  mtoa_shaders.dll: MayaVolumeNoise uses Arnold 6.0.1.0
00:00:00  7731MB         |  mtoa_shaders.dll: MayaBrownian uses Arnold 6.0.1.0
00:00:00  7732MB         |  mtoa_shaders.dll: MayaStucco uses Arnold 6.0.1.0
00:00:00  7732MB         |  mtoa_shaders.dll: MayaRemapHsv uses Arnold 6.0.1.0
00:00:00  7733MB         |  mtoa_shaders.dll: MayaSetRange uses Arnold 6.0.1.0
00:00:00  7734MB         |  mtoa_shaders.dll: MayaImagePlane uses Arnold 6.0.1.0
00:00:00  7735MB         |  mtoa_shaders.dll: MayaSurfaceShader uses Arnold 6.0.1.0
00:00:00  7736MB         |  mtoa_shaders.dll: MtoaColorToFloat uses Arnold 6.0.1.0
00:00:00  7737MB         |  mtoa_shaders.dll: MtoaVectorToFloat uses Arnold 6.0.1.0
00:00:00  7738MB         |  mtoa_shaders.dll: MtoaPointToFloat uses Arnold 6.0.1.0
00:00:00  7738MB         |  mtoa_shaders.dll: MtoaPoint2ToFloat uses Arnold 6.0.1.0
00:00:00  7739MB         |  mtoa_shaders.dll: MtoaWriteColor uses Arnold 6.0.1.0
00:00:00  7730MB         |  mtoa_shaders.dll: MtoaAovWriteColor uses Arnold 6.0.1.0
00:00:00  7731MB         |  mtoa_shaders.dll: MtoaWriteFloat uses Arnold 6.0.1.0
00:00:00  7731MB         |  mtoa_shaders.dll: MtoaAovWriteFloat uses Arnold 6.0.1.0
00:00:00  7732MB         |  mtoa_shaders.dll: MayaEnvSphere uses Arnold 6.0.1.0
00:00:00  7733MB         |  mtoa_shaders.dll: MtoaAnimFloat uses Arnold 6.0.1.0
00:00:00  7733MB         |  mtoa_shaders.dll: MtoaAnimPoint uses Arnold 6.0.1.0
00:00:00  7734MB         |  mtoa_shaders.dll: MtoaAnimVector uses Arnold 6.0.1.0
00:00:00  7735MB         |  mtoa_shaders.dll: MtoaAnimColor uses Arnold 6.0.1.0
00:00:00  7735MB         |  mtoa_shaders.dll: MtoaAnimMatrix uses Arnold 6.0.1.0
00:00:00  7736MB         |  mtoa_shaders.dll: MtoaUserDataVector uses Arnold 6.0.1.0
00:00:00  7736MB         |  mtoa_shaders.dll: MtoaUserDataColor uses Arnold 6.0.1.0
00:00:00  7737MB         |  mtoa_shaders.dll: MayaShadingEngine uses Arnold 6.0.1.0
00:00:00  7730MB         |  mtoa_shaders.dll: MayaSamplerInfo3D uses Arnold 6.0.1.0
00:00:00  7732MB         |  mtoa_shaders.dll: MtoaAovWriteVector uses Arnold 6.0.1.0
00:00:00  7732MB         |  mtoa_shaders.dll: MtoaAovWriteVector2 uses Arnold 6.0.1.0
00:00:00  7734MB         |  mtoa_shaders.dll: MayaNormalDisplacement uses Arnold 6.0.1.0
00:00:00  7735MB         |  mtoa_shaders.dll: MayaVectorDisplacement uses Arnold 6.0.1.0
00:00:00  7736MB         |  mtoa_shaders.dll: MtoaUserDataBool uses Arnold 6.0.1.0
00:00:00  7737MB         |  mtoa_shaders.dll: MayaHair uses Arnold 6.0.1.0
00:00:00  7739MB         |  mtoa_shaders.dll: MtoaMeshLightMaterial uses Arnold 6.0.1.0
00:00:00  7740MB         |  mtoa_shaders.dll: MtoaUserDataVec2 uses Arnold 6.0.1.0
00:00:00  7741MB         |  mtoa_shaders.dll: MayaBump2D uses Arnold 6.0.1.0
00:00:00  7742MB         |  mtoa_shaders.dll: MayaFluid uses Arnold 6.0.1.0
00:00:00  7743MB         |  mtoa_shaders.dll: MayaMarble uses Arnold 6.0.1.0
00:00:00  7730MB         |  mtoa_shaders.dll: MayaMountain uses Arnold 6.0.1.0
00:00:00  7731MB         |  mtoa_shaders.dll: MayaWater uses Arnold 6.0.1.0
00:00:00  7732MB         |  mtoa_shaders.dll: MayaCrater uses Arnold 6.0.1.0
00:00:00  7733MB         |  mtoa_shaders.dll: MayaLeather uses Arnold 6.0.1.0
00:00:00  7734MB         |  mtoa_shaders.dll: MayaGranite uses Arnold 6.0.1.0
00:00:00  7735MB         |  mtoa_shaders.dll: MayaRock uses Arnold 6.0.1.0
00:00:00  7736MB         |  mtoa_shaders.dll: MayaSingleShadingSwitch uses Arnold 6.0.1.0
00:00:00  7738MB         |  mtoa_shaders.dll: MayaDoubleShadingSwitch uses Arnold 6.0.1.0
00:00:00  7739MB         |  mtoa_shaders.dll: MayaTripleShadingSwitch uses Arnold 6.0.1.0
00:00:00  7740MB         |  mtoa_shaders.dll: MayaQuadShadingSwitch uses Arnold 6.0.1.0
00:00:00  7741MB         |  mtoa_shaders.dll: MayaFluidData uses Arnold 6.0.1.0
00:00:00  7742MB         |  mtoa_shaders.dll: MayaFluidTexture2D uses Arnold 6.0.1.0
00:00:00  7730MB         |  mtoa_shaders.dll: MayaSurfaceLuminance uses Arnold 6.0.1.0
00:00:00  7731MB         |  mtoa_shaders.dll: MtoaCameraUvMapper uses Arnold 6.0.1.0
00:00:00  7731MB         |  mtoa_shaders.dll: MayaFlatClosure uses Arnold 6.0.1.0
00:00:00  7732MB         |  renderSetup_shaders.dll: applyAbsFloatOverride uses Arnold 6.0.1.0
00:00:00  7733MB         |  renderSetup_shaders.dll: applyAbs2FloatsOverride uses Arnold 6.0.1.0
00:00:00  7734MB         |  renderSetup_shaders.dll: applyAbs3FloatsOverride uses Arnold 6.0.1.0
00:00:00  7735MB         |  renderSetup_shaders.dll: applyAbsIntOverride uses Arnold 6.0.1.0
00:00:00  7736MB         |  renderSetup_shaders.dll: applyRelFloatOverride uses Arnold 6.0.1.0
00:00:00  7737MB         |  renderSetup_shaders.dll: applyRel2FloatsOverride uses Arnold 6.0.1.0
00:00:00  7737MB         |  renderSetup_shaders.dll: applyRel3FloatsOverride uses Arnold 6.0.1.0
00:00:00  7738MB         |  renderSetup_shaders.dll: applyRelIntOverride uses Arnold 6.0.1.0
00:00:00  7730MB         |  xgenSpline_shaders.dll: XGenHairMapping uses Arnold 6.0.1.0
00:00:00  7731MB         | loading plugins from C:/Program Files/Autodesk/Arnold/maya2020/procedurals ...
00:00:00  7732MB         |  mtoa_ParticleInstancer_proc.dll: particleInstancer uses Arnold 6.0.1.0
00:00:00  7733MB         |  mtoa_ParticleVolume_proc.dll: volume_particle uses Arnold 6.0.1.0
00:00:00  7734MB         |  mtoa_ParticleVolume_proc.dll: implicit_particle uses Arnold 6.0.1.0
00:00:00  7735MB         |  xgenSpline_procedural.dll: xgenProcedural uses Arnold 6.0.1.0
00:00:00  7735MB         |  xgen_procedural.dll: xgen_procedural uses Arnold 6.0.1.0
00:00:00  7736MB         | loaded 121 plugins from 9 lib(s) in 0:00.01
00:00:00  7737MB         | loading plugins from C:\Program Files\Autodesk\Arnold\maya2020\bin\..\plugins ...
00:00:00  7738MB         |  alembic_proc.dll: alembic uses Arnold 6.0.1.0
00:00:00  7738MB         |  cryptomatte.dll: cryptomatte uses Arnold 6.0.1.0
00:00:00  7731MB         |  cryptomatte.dll: cryptomatte_filter uses Arnold 6.0.1.0
00:00:00  7732MB         |  cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 6.0.1.0
00:00:00  7733MB         |  synColor_shaders.dll: color_manager_syncolor uses Arnold 6.0.1.0
00:00:00  7735MB         | loaded 5 plugins from 3 lib(s) in 0:00.00
00:00:02  7736MB         |   [mtoa] RGBA attribute file6.defaultColor has no alpha component: exporting as RGBA
00:00:02  7735MB         |    [mtoa] RGBA attribute NormalMap__5__1.defaultColor has no alpha component: exporting as RGBA
00:00:03  7730MB         |    [mtoa] RGBA attribute file9.defaultColor has no alpha component: exporting as RGBA
00:00:03  7736MB         |   [mtoa] RGBA attribute file10.defaultColor has no alpha component: exporting as RGBA
00:00:03  7736MB         |    [mtoa] RGBA attribute file11.defaultColor has no alpha component: exporting as RGBA
00:00:03  7730MB         |   [mtoa] RGBA attribute file7.defaultColor has no alpha component: exporting as RGBA
00:00:03  7740MB         |   [mtoa] RGBA attribute SpecularMap__3__1.defaultColor has no alpha component: exporting as RGBA
00:00:03  7736MB         |   [mtoa] RGBA attribute Metalness_1.defaultColor has no alpha component: exporting as RGBA
00:00:03  7732MB WARNING | [mtoa] Failed to export mesh for mesh_light
00:00:03  7735MB         |   [mtoa] RGBA attribute file5.defaultColor has no alpha component: exporting as RGBA
00:00:03  7741MB         |   [mtoa] RGBA attribute file3.defaultColor has no alpha component: exporting as RGBA
00:00:03  7739MB         |   [mtoa] RGBA attribute file4.defaultColor has no alpha component: exporting as RGBA
00:00:04  7730MB         |   [mtoa] RGBA attribute file2.defaultColor has no alpha component: exporting as RGBA
00:00:04  7733MB         |   [mtoa] RGBA attribute file8.defaultColor has no alpha component: exporting as RGBA
00:00:06  7730MB         | [color_manager_syncolor] synColor version 2018.0.80
00:00:06  7730MB         | [color_manager_syncolor] native catolog directory: C:/Program Files/Autodesk/Maya2020/synColor
00:00:06  7731MB         | [color_manager_syncolor] optional custom catalog directory: C:/Users/coryc/Documents/maya/synColor/Shared/
00:00:06  7806MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/BaseMap.tx"
00:00:06  7820MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/Greed.tx"
00:00:06  7835MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/normal3.tx"
00:00:06  7839MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/normal5.tx"
00:00:06  7846MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/SpecularMap (3).tx"
00:00:06  7837MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/Wrath.tx"
00:00:06  7827MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/Gluttony.tx"
00:00:06  7829MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/Metalnessv2.tx"
00:00:06  7833MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/Sloth.tx"
00:00:06  7837MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/Pride.tx"
00:00:06  7842MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/Envy.tx"
00:00:06  7846MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/Passion.tx"
00:00:06  7805MB         | [AiMakeTx] maketx: no update required for "//eris/Edit/Daz3d/Shattered Star/Trailer/ShardNormalv2.tx"
00:00:06  7730MB         |
00:00:06  7731MB         | [gpu] setting OptiX disk cache location to: C:\Users\coryc\AppData\Local/NVIDIA/OptixCache/arnold-6.0.1.0_driver-441.66
00:00:06  7731MB         |  GPU 0: Quadro P5000 enabled
00:00:06  7731MB         |  GPU 1: Quadro P5000 enabled
00:00:06  7732MB         |  GPU 2: Quadro P4000 enabled
00:00:06  7734MB         | [color_manager] using color manager of type "color_manager_syncolor"
00:00:06  7735MB         | [color_manager] rendering color space is "scene-linear Rec 709/sRGB" with declared chromaticities:
00:00:06  7736MB         |                 r(0.6400, 0.3300) g(0.3000, 0.6000) b(0.1500, 0.0600) and w(0.3127, 0.3290)
00:00:07  7748MB         |
00:00:07  7748MB         | there are 39 lights and 134 objects:
00:00:07  7749MB         |       1 persp_camera
00:00:07  7749MB         |       3 quad_light
00:00:07  7750MB         |       1 spot_light
00:00:07  7752MB         |      35 mesh_light
00:00:07  7752MB         |      35 ray_switch_shader
00:00:07  7753MB         |      13 image
00:00:07  7754MB         |       1 utility
00:00:07  7754MB         |      17 standard_surface
00:00:07  7755MB         |       1 bump2d
00:00:07  7756MB         |       1 atmosphere_volume
00:00:07  7757MB         |       3 color_correct
00:00:07  7757MB         |      35 multiply
00:00:07  7758MB         |       2 normal_map
00:00:07  7759MB         |      35 two_sided
00:00:07  7759MB         |       1 driver_jpeg
00:00:07  7760MB         |       1 gaussian_filter
00:00:07  7761MB         |     133 polymesh
00:00:07  7761MB         |       1 list_aggregate
00:00:07  7762MB         |       1 color_manager_syncolor
00:00:07  7748MB         |       1 renderview_display
00:00:07  7749MB         |
00:00:07  7750MB         | rendering image at 960 x 540, 3 AA samples
00:00:07  7751MB         |   AA samples max    <disabled>
00:00:07  7752MB         |   AA sample clamp   <disabled>
00:00:07  7753MB         |   diffuse           samples  1 / depth  1
00:00:07  7753MB         |   specular          samples  1 / depth  1
00:00:07  7754MB         |   transmission      samples  1 / depth  8
00:00:07  7755MB         |   volume indirect   <disabled by depth>
00:00:07  7756MB         |   total                          depth 10
00:00:07  7757MB         |   bssrdf            samples  1
00:00:07  7758MB         |   transparency      depth 10
00:00:07  7758MB         |  initializing 322 nodes ...
00:00:07  7755MB         |   creating root object list ...
00:00:07  7755MB         |  node initialization done in 0:00.01 (multithreaded)
00:00:07  7756MB         |  updating 323 nodes ...
00:00:07  7757MB         |   /spotLight1/spotLightShape1: disabled spot_light
00:00:07  7757MB         |   aiAtmosphereVolume: atmosphere_volume using 5 samples
00:00:07  7758MB         |   /Sihedron/Sloth_Group/ShardSloth1/SlothLightMesh/light_Sloth2/light_Sloth2Shape: mesh_light using 1 sample, 2 volume samples
00:00:07  7758MB         |   /Sihedron/Greed_Group/Shard_Greed/light_GreedLight/light_GreedLightShape: mesh_light using 1 sample, 2 volume samples
00:00:07  7758MB         |   /Sihedron/Sloth_Group/ShardSloth1/GemSloth/light_GemSloth/light_GemSlothShape: disabled mesh_light
00:00:07  7761MB         |   /Sihedron/Greed_Group/Shard_Greed/GemGreed/light_GemGreed/light_GemGreedShape: disabled mesh_light
00:00:07  7761MB         |   /Sihedron/Gluttony_Group/ShardGluttony1/SymbolGluttony1/light_Gluttony/light_GluttonyShape: mesh_light using 1 sample, 2 volume samples
00:00:07  7758MB         |   /Sihedron/Gluttony_Group/ShardGluttony1/GemGluttony/light_GemGluttony/light_GemGluttonyShape: disabled mesh_light
00:00:07  7759MB         |   /Sihedron/Wrath_Group/ShardWrath1/GemWrath/light_GemWrath/light_GemWrathShape: disabled mesh_light
00:00:07  7760MB         |   /Sihedron/Passion_Group/ShardPassion1/GemPassion/light_GemPassion/light_GemPassionShape: disabled mesh_light
00:00:07  7759MB         |   /Sihedron/Passion_Group/ShardPassion1/PassionLightMesh/light_Passion/light_PassionShape: mesh_light using 1 sample, 2 volume samples
00:00:07  7759MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_C2/light_C2Shape: disabled mesh_light
00:00:07  7758MB         |   /Sihedron/Wrath_Group/ShardWrath1/SymbolWrath1/light_Wrath/light_WrathShape: mesh_light using 1 sample, 2 volume samples
00:00:07  7759MB         |   /Sihedron/Pride_Group/ShardPride1/PrideLightMesh/light_Pride2/light_Pride2Shape: mesh_light using 1 sample, 2 volume samples
00:00:07  7758MB         |   /Sihedron/Envy_Group/ShardEnvy1/GemEnvy/light_GemEnvy/light_GemEnvyShape: disabled mesh_light
00:00:07  7758MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_Z/light_ZShape: disabled mesh_light
00:00:07  7759MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_C/light_CShape: mesh_light using 1 sample, 2 volume samples
00:00:07  7758MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_R/light_RShape: disabled mesh_light
00:00:07  7759MB         |   /Sihedron/Envy_Group/ShardEnvy1/EnvyLightMesh/light_Envy2/light_Envy2Shape: mesh_light using 1 sample, 2 volume samples
00:00:07  7759MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_Z2/light_Z2Shape: disabled mesh_light
00:00:07  7758MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_NewY/light_NewYShape: disabled mesh_light
00:00:07  7759MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_Y/light_YShape: disabled mesh_light
00:00:07  7759MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/polySurface15/light_fancyX/light_fancyXShape: disabled mesh_light
00:00:07  7760MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_N/light_NShape: disabled mesh_light
00:00:07  7760MB         |   /aiAreaLight4__Front_/aiAreaLight4__Front_Shape: quad_light using 1 sample, 2 volume samples
00:00:07  7761MB         |   /Bright_light/Bright_lightShape: quad_light using 1 sample, 2 volume samples
00:00:07  7760MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_Y3/light_Y3Shape: disabled mesh_light
00:00:07  7759MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_Y2/light_Y2Shape: disabled mesh_light
00:00:07  7761MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_F/light_FShape: disabled mesh_light
00:00:07  7759MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_X/light_XShape: disabled mesh_light
00:00:07  7765MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_F2/light_F2Shape: disabled mesh_light
00:00:07  7765MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_X3/light_X3Shape: disabled mesh_light
00:00:07  7765MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/Light_N2/Light_N2Shape: disabled mesh_light
00:00:07  7766MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_Z4/light_Z4Shape: disabled mesh_light
00:00:07  7766MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_F3/light_F3Shape: disabled mesh_light
00:00:07  7766MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_Y4/light_Y4Shape: disabled mesh_light
00:00:07  7766MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_C3/light_C3Shape: disabled mesh_light
00:00:07  7765MB         |   /Sihedron/Pride_Group/ShardPride1/GemPride/light_GemPride/light_GemPrideShape: disabled mesh_light
00:00:07  7762MB         |   /Sihedron/Center_Circle_Shatter/RuneLights/light_F4/light_F4Shape: disabled mesh_light
00:00:07  7763MB WARNING |   /Sihedron/Center_Circle_Shatter/RuneLights/light_Y4/light_Y4Shape: no polymesh linked to mesh_light
00:00:07  7762MB         |   /aiAreaLight3_Back/aiAreaLight3_BackShape: quad_light using 1 sample, 2 volume samples
00:00:07  7762MB         |   scene bounds: (-4.73332071 -0.0746807903 -2.51797342) -> (2.0283432 50.5765152 2.35953093)
00:00:07  7763MB         |  node update done in 0:00.20 (multithreaded)
00:00:07  7773MB         |  [gpu] preparing 323 nodes ...
00:00:08  7779MB         |  [gpu] updating 323 nodes ...
00:00:09  7797MB         |  [aov] parsing 2 output statements ...
00:00:09  7797MB         |  [aov] registered driver: "defaultArnoldDriver@driver_jpeg.RGBA" (driver_jpeg)
00:00:09  7798MB         |  [aov]  * "RGBA" of type RGBA filtered by "defaultArnoldFilter@gaussian_filter" (gaussian_filter)
00:00:09  7799MB         |  [aov] registered driver: "defaultArnoldDisplayDriver@renderview_display" (renderview_display)
00:00:09  7799MB         |  [aov]  * "RGBA" of type RGBA filtered by "defaultArnoldFilter@gaussian_filter" (gaussian_filter)
00:00:09  7800MB         |  [aov] done preparing 2 AOVs for 2 outputs to 2 drivers (0 deep AOVs)
00:00:09  7838MB         |  starting render ...
00:00:09  7818MB         |   [gpu] building scene and compiling shaders ...
00:00:10  8075MB         |   [gpu] building scene and compiling shaders done in 0:01.473
00:00:10  8075MB         |     0% done (0/9 samples per pixel)
00:00:11  8210MB ERROR   |   [gpu] an error happened during rendering : Unknown error (Details: Function "_rtContextLaunch2D" caught exception: Encountered a CUDA error: cudaDriver().CuEventSynchronize( m_event ) returned (700): Illegal address)
00:00:13  8390MB ERROR   |   signal caught: error E06D7363
Message 7 of 16
Is all of the info you need in that log file Stephen?
Message 8 of 16
dluna007
It is happening the same w me. CPU rendering in sequence is working fine, but in GPU it is freezing Maya and just render the first frame and when it start to render the second frame, it freeze and the next frame stay w 0 kb. Have to turn off using the Task Manager.
And I did a sequence render using GPU before, and it was working.
Something broke it, I even tryed to export/import everything to a new scene and nothing worked.
Message 9 of 16
cartscal
in reply to: dluna007
Same here, I'm running an RTX 2070 and it freezes before rendering the first frame. This is after I have ran the pre-cache utility for the GPU. Does not crash on CPU renders with the same settings. My nvidia drivers are up to date and I am running MAYA 2020 and Arnold 2020.
Message 10 of 16
jordan.giboney
in reply to: cartscal
Hi @cartscal
Thanks for posting! Could you share your Arnold.log files with us? That will help us understand your setup and may give us a specific error 🙂
Here's how to get the .log file: How to get an Arnold .log file (set verbosity level to at least Info in Render Settings > Diagnostics).
Thanks for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 11 of 16
cartscal
in reply to: jordan.giboney
Hello, thank you for the quick reply.
To better aid the tests I set the render settings to default and only changed the render to GPU, and enabled the diagnostic logs. It's worth noting that I was able to render 1000 frames using the CPU setting but received errors immediately with GPU. Below I've listed 2 logs, the first log is a render with the GPU of a single frame, and the second log is a render with the GPU for 5 frames. Both renders were initiated using the "render sequence" button. It is also worth noting that the Arnold render preview does not work when the Gpu is selected, only with the Cpu selected in the render settings.
FIRST LOG STARTS HERE, RENDERING 1 FRAME
00:00:00 3089MB | log started Tue May 12 13:54:43 2020
00:00:00 3089MB | Arnold 6.0.2.0 [46703ee7] windows icc-17.0.2 oiio-2.1.4 osl-1.11.0 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.5.0 2020/02/12 19:28:33
00:00:00 3089MB | host application: MtoA 4.0.2 46d4a92e (master) Maya 2020
00:00:00 3089MB | running on DESKTOP-KIAFN60, pid=8508
00:00:00 3089MB | 1 x Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz (8 cores, 8 logical) with 16315MB
00:00:00 3089MB | NVIDIA driver version 445.87 (Optix 60700)
00:00:00 3089MB | GPU 0: GeForce RTX 2070 @ 1620MHz (compute 7.5) with 8192MB (3454MB available) (NVLink:0)
00:00:00 3089MB |
00:00:00 3089MB | soft limit for open files raised from 2048 to 2048
00:00:00 3089MB |
00:00:00 3089MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2020/shaders ...
00:00:00 3089MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2020/procedurals ...
00:00:00 3089MB | loaded 121 plugins from 9 lib(s) in 0:00.00
00:00:00 3089MB | loading plugins from C:\Program Files\Autodesk\Arnold\maya2020\bin\..\plugins ...
00:00:00 3089MB | loaded 6 plugins from 4 lib(s) in 0:00.06
00:00:00 3089MB WARNING | unable to create log file D:/Error Log/info.1.*: Invalid argument
00:00:00 3089MB | loading plugin: C:/Program Files/Autodesk/Bifrost/Maya2020/2.0.5.0/bifrost/arnold-6.0.0.0/arnold_bifrost.dll ...
00:00:00 3090MB | loaded 9 plugins from 1 lib(s) in 0:00.00
00:00:00 3090MB | [mtoa] RGBA attribute pasted__file20.defaultColor has no alpha component: exporting as RGBA
00:00:00 3090MB | [mtoa] RGBA attribute pasted__file15.defaultColor has no alpha component: exporting as RGBA
00:00:00 3090MB | [mtoa] RGBA attribute pasted__file14.defaultColor has no alpha component: exporting as RGBA
00:00:00 3090MB | [mtoa] RGBA attribute pasted__file17.defaultColor has no alpha component: exporting as RGBA
00:00:00 3090MB | [mtoa] RGBA attribute pasted__file11.defaultColor has no alpha component: exporting as RGBA
00:00:00 3090MB | [mtoa] RGBA attribute pasted__pasted__file1.defaultColor has no alpha component: exporting as RGBA
00:00:00 3090MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file24.defaultColor has no alpha component: exporting as RGBA
00:00:00 3090MB | [mtoa] RGBA attribute pasted__file19.defaultColor has no alpha component: exporting as RGBA
00:00:00 3090MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 0 on mesh group79Shape.
00:00:00 3090MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 1 on mesh group79Shape.
00:00:00 3090MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 2 on mesh group79Shape.
00:00:00 3090MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 3 on mesh group79Shape.
00:00:00 3090MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 13 at vertex 0 on mesh group79Shape.
00:00:00 3090MB | [mtoa] RGBA attribute file11.defaultColor has no alpha component: exporting as RGBA
00:00:00 3090MB | [mtoa] RGBA attribute file12.defaultColor has no alpha component: exporting as RGBA
00:00:00 3090MB | [mtoa] RGBA attribute file13.defaultColor has no alpha component: exporting as RGBA
00:00:00 3090MB | [mtoa] RGBA attribute file14.defaultColor has no alpha component: exporting as RGBA
00:00:00 3091MB | [mtoa] RGBA attribute pasted__file24.defaultColor has no alpha component: exporting as RGBA
00:00:00 3091MB | [mtoa] RGBA attribute pasted__file23.defaultColor has no alpha component: exporting as RGBA
00:00:00 3091MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file26.defaultColor has no alpha component: exporting as RGBA
00:00:00 3092MB | [mtoa] RGBA attribute file9.defaultColor has no alpha component: exporting as RGBA
00:00:00 3092MB | [mtoa] RGBA attribute pasted__file5.defaultColor has no alpha component: exporting as RGBA
00:00:00 3092MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file30.defaultColor has no alpha component: exporting as RGBA
00:00:00 3092MB | [mtoa] RGBA attribute pasted__file18.defaultColor has no alpha component: exporting as RGBA
00:00:00 3093MB | [mtoa] RGBA attribute pasted__file26.defaultColor has no alpha component: exporting as RGBA
00:00:00 3093MB | [mtoa] RGBA attribute pasted__file27.defaultColor has no alpha component: exporting as RGBA
00:00:00 3093MB | [mtoa] RGBA attribute pasted__file28.defaultColor has no alpha component: exporting as RGBA
00:00:00 3097MB | [mtoa] RGBA attribute file2.defaultColor has no alpha component: exporting as RGBA
00:00:00 3097MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file23.defaultColor has no alpha component: exporting as RGBA
00:00:00 3098MB | [mtoa] RGBA attribute file17.defaultColor has no alpha component: exporting as RGBA
00:00:00 3098MB | [mtoa] RGBA attribute file18.defaultColor has no alpha component: exporting as RGBA
00:00:00 3098MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file28.defaultColor has no alpha component: exporting as RGBA
00:00:00 3099MB | [mtoa] RGBA attribute file10.defaultColor has no alpha component: exporting as RGBA
00:00:00 3099MB | [mtoa] RGBA attribute file4.defaultColor has no alpha component: exporting as RGBA
00:00:00 3099MB | [mtoa] RGBA attribute file3.defaultColor has no alpha component: exporting as RGBA
00:00:00 3100MB | [mtoa] RGBA attribute file8.defaultColor has no alpha component: exporting as RGBA
00:00:01 3101MB | [mtoa] RGBA attribute file6.defaultColor has no alpha component: exporting as RGBA
00:00:01 3102MB | [mtoa] RGBA attribute pasted__file25.defaultColor has no alpha component: exporting as RGBA
00:00:01 3144MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file20.defaultColor has no alpha component: exporting as RGBA
00:00:01 3144MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file21.defaultColor has no alpha component: exporting as RGBA
00:00:01 3144MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file3.defaultColor has no alpha component: exporting as RGBA
00:00:01 3042MB | [color_manager_syncolor] synColor version 2018.0.80
00:00:01 3042MB | [color_manager_syncolor] native catolog directory: C:/Program Files/Autodesk/Maya2020/synColor
00:00:01 3042MB | [color_manager_syncolor] optional custom catalog directory: C:/Users/carte/Documents/maya/synColor/Shared/
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Body-Spec_u0_v0.tx"
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/FenceUV.tx"
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Le Road.tx"
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Tongue-TM_u0_v0.tx"
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/MoreBuilding.tx"
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Spines-TM_u0_v0.tx"
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/MonsterHouseUV.tx"
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_wall2.tx"
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Bricks.tx"
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/FencePostUV.tx"
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/RoofUV.tx"
00:00:01 3043MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/TreeLeaves.tx"
00:00:01 3056MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/RedBrickBuilding1.tx"
00:00:01 3068MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/TreeLeavesAlpha.tx"
00:00:01 3068MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_wall1.tx"
00:00:01 3068MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/TreeBark.tx"
00:00:01 3068MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_concrete1.tx"
00:00:01 3068MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Teeth-TM_u0_v0.tx"
00:00:01 3068MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Eyes_mem-TM_u0_v0.tx"
00:00:01 3068MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/52c51e8f930c5376b85421b7bc9786e9.tx"
00:00:01 3044MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/hw bg newtransparent.tx"
00:00:01 3044MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/hw bg newtransparent_ALPHA.tx"
00:00:01 3044MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_wall3.tx"
00:00:01 3044MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Eyes-TM_u0_v0.tx"
00:00:01 3044MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Church Textures.tx"
00:00:01 3044MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Groundcover.tx"
00:00:01 3044MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Body-TM_u0_v0.tx"
00:00:01 3044MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Body-DM8192_u0_v0.tx"
00:00:01 3043MB |
00:00:01 3044MB | [gpu] setting OptiX disk cache location to: C:\Users\carte\AppData\Local/NVIDIA/OptixCache/arnold-6.0.2.0_driver-445.87
00:00:01 3047MB | GPU 0: GeForce RTX 2070 enabled
00:00:01 3048MB | [color_manager] using color manager of type "color_manager_syncolor"
00:00:01 3048MB | [color_manager] rendering color space is "scene-linear Rec 709/sRGB" with declared chromaticities:
00:00:01 3048MB | r(0.6400, 0.3300) g(0.3000, 0.6000) b(0.1500, 0.0600) and w(0.3127, 0.3290)
00:00:01 3067MB |
00:00:01 3067MB | there are 1 light and 2001 objects:
00:00:01 3067MB | 3 persp_camera
00:00:01 3067MB | 1 ortho_camera
00:00:01 3067MB | 1 skydome_light
00:00:01 3067MB | 36 image
00:00:01 3067MB | 1 utility
00:00:01 3067MB | 19 lambert
00:00:01 3067MB | 18 standard_surface
00:00:01 3067MB | 1 color_correct
00:00:01 3067MB | 1 complement
00:00:01 3067MB | 1 range
00:00:01 3067MB | 1 driver_exr
00:00:01 3067MB | 1 gaussian_filter
00:00:01 3067MB | 2000 polymesh
00:00:01 3067MB | 1 list_aggregate
00:00:01 3067MB | 1 color_manager_syncolor
00:00:01 3067MB | 1 renderview_display
00:00:01 3067MB |
00:00:01 3067MB | rendering image at 960 x 540, 3 AA samples
00:00:01 3067MB | AA samples max <disabled>
00:00:01 3067MB | AA sample clamp <disabled>
00:00:01 3067MB | diffuse samples 2 / depth 1
00:00:01 3067MB | specular samples 2 / depth 1
00:00:01 3067MB | transmission samples 2 / depth 8
00:00:01 3067MB | volume indirect <disabled by depth>
00:00:01 3067MB | total depth 10
00:00:01 3067MB | bssrdf samples 2
00:00:01 3067MB | transparency depth 10
00:00:01 3067MB | initializing 2088 nodes ...
00:00:01 3089MB | creating root object list ...
00:00:01 3089MB | node initialization done in 0:00.01 (multithreaded)
00:00:01 3089MB | updating 2089 nodes ...
00:00:01 3103MB | scene bounds: (-3478.05713 -84.1937561 -3332.56396) -> (3349.84033 848.516846 4843.41113)
00:00:01 3103MB | node update done in 0:00.06 (multithreaded)
00:00:01 3103MB | [gpu] preparing 2089 nodes ...
00:00:02 3166MB | [gpu] updating 2089 nodes ...
00:00:05 3293MB | [skydome_light] /aiSkyDomeLight2/aiSkyDomeLightShape2: 1000x1000 importance map done in 0:01.65, average energy 0.468460
00:00:05 3309MB | [aov] parsing 2 output statements ...
00:00:05 3309MB | [aov] registered driver: "defaultArnoldDisplayDriver@renderview_display" (renderview_display)
00:00:05 3309MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter@gaussian_filter" (gaussian_filter)
00:00:05 3309MB | [aov] registered driver: "defaultArnoldDriver@driver_exr.RGBA" (driver_exr)
00:00:05 3309MB | [aov] done preparing 2 AOVs for 2 outputs to 2 drivers (0 deep AOVs)
00:00:05 3342MB | starting render ...
00:00:05 3363MB ERROR | [gpu] an error happened during rendering : Unknown error
00:00:05 3363MB | [driver_exr] writing file `D:/Images/Arnold_Render_1.exr'
00:00:05 3364MB | render done
00:00:05 3341MB |
00:00:05 3341MB | releasing resources
SECOND LOG STARTS HERE, SAME SETTINGS, ONLY 5 FRAMES THIS TIME INSTEAD OF 1 FRAME
00:00:00 2362MB | log started Tue May 12 15:19:53 2020
00:00:00 2362MB | Arnold 6.0.2.0 [46703ee7] windows icc-17.0.2 oiio-2.1.4 osl-1.11.0 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.5.0 2020/02/12 19:28:33
00:00:00 2362MB | running on DESKTOP-KIAFN60, pid=9648
00:00:00 2362MB | 1 x Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz (8 cores, 8 logical) with 16315MB
00:00:00 2362MB | NVIDIA driver version 445.87 (Optix 60700)
00:00:00 2362MB | GPU 0: GeForce RTX 2070 @ 1620MHz (compute 7.5) with 8192MB (6861MB available) (NVLink:0)
00:00:00 2362MB |
00:00:00 2362MB | soft limit for open files raised from 2048 to 2048
00:00:00 2362MB |
00:00:00 2362MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2020/shaders ...
00:00:00 2362MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2020/procedurals ...
00:00:00 2362MB | loaded 121 plugins from 9 lib(s) in 0:00.00
00:00:00 2362MB | loading plugins from C:\Program Files\Autodesk\Arnold\maya2020\bin\..\plugins ...
00:00:00 2362MB | loaded 6 plugins from 4 lib(s) in 0:00.06
00:00:00 2362MB |
00:00:00 2362MB | releasing resources
00:00:00 2358MB | Arnold shutdown
00:00:00 2138MB | log started Tue May 12 15:20:19 2020
00:00:00 2138MB | Arnold 6.0.2.0 [46703ee7] windows icc-17.0.2 oiio-2.1.4 osl-1.11.0 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.5.0 2020/02/12 19:28:33
00:00:00 2138MB | host application: MtoA 4.0.2 46d4a92e (master) Maya 2020
00:00:00 2138MB | running on DESKTOP-KIAFN60, pid=9648
00:00:00 2138MB | 1 x Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz (8 cores, 8 logical) with 16315MB
00:00:00 2138MB | NVIDIA driver version 445.87 (Optix 60700)
00:00:00 2138MB | GPU 0: GeForce RTX 2070 @ 1620MHz (compute 7.5) with 8192MB (3932MB available) (NVLink:0)
00:00:00 2138MB |
00:00:00 2138MB | soft limit for open files raised from 2048 to 2048
00:00:00 2138MB |
00:00:00 2138MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2020/shaders ...
00:00:00 2138MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2020/procedurals ...
00:00:00 2138MB | loaded 121 plugins from 9 lib(s) in 0:00.00
00:00:00 2138MB | loading plugins from C:\Program Files\Autodesk\Arnold\maya2020\bin\..\plugins ...
00:00:00 2138MB | loaded 6 plugins from 4 lib(s) in 0:00.07
00:00:00 2138MB WARNING | unable to create log file D:/Error Log/info.1.*: Invalid argument
00:00:00 2138MB | loading plugin: C:/Program Files/Autodesk/Bifrost/Maya2020/2.0.5.0/bifrost/arnold-6.0.0.0/arnold_bifrost.dll ...
00:00:00 2139MB | loaded 9 plugins from 1 lib(s) in 0:00.00
00:00:00 2145MB | [mtoa] RGBA attribute pasted__file11.defaultColor has no alpha component: exporting as RGBA
00:00:00 2145MB | [mtoa] RGBA attribute pasted__file20.defaultColor has no alpha component: exporting as RGBA
00:00:00 2145MB | [mtoa] RGBA attribute pasted__file15.defaultColor has no alpha component: exporting as RGBA
00:00:00 2145MB | [mtoa] RGBA attribute pasted__file26.defaultColor has no alpha component: exporting as RGBA
00:00:00 2145MB | [mtoa] RGBA attribute pasted__file27.defaultColor has no alpha component: exporting as RGBA
00:00:00 2145MB | [mtoa] RGBA attribute pasted__file28.defaultColor has no alpha component: exporting as RGBA
00:00:00 2145MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file24.defaultColor has no alpha component: exporting as RGBA
00:00:00 2145MB | [mtoa] RGBA attribute pasted__file14.defaultColor has no alpha component: exporting as RGBA
00:00:00 2145MB | [mtoa] RGBA attribute file12.defaultColor has no alpha component: exporting as RGBA
00:00:00 2145MB | [mtoa] RGBA attribute file13.defaultColor has no alpha component: exporting as RGBA
00:00:00 2145MB | [mtoa] RGBA attribute file14.defaultColor has no alpha component: exporting as RGBA
00:00:00 2146MB | [mtoa] RGBA attribute pasted__pasted__file1.defaultColor has no alpha component: exporting as RGBA
00:00:00 2146MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file28.defaultColor has no alpha component: exporting as RGBA
00:00:00 2146MB | [mtoa] RGBA attribute pasted__file17.defaultColor has no alpha component: exporting as RGBA
00:00:00 2146MB | [mtoa] RGBA attribute file11.defaultColor has no alpha component: exporting as RGBA
00:00:00 2146MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file26.defaultColor has no alpha component: exporting as RGBA
00:00:00 2146MB | [mtoa] RGBA attribute pasted__file24.defaultColor has no alpha component: exporting as RGBA
00:00:00 2147MB | [mtoa] RGBA attribute pasted__file19.defaultColor has no alpha component: exporting as RGBA
00:00:00 2147MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 0 on mesh group79Shape.
00:00:00 2147MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 1 on mesh group79Shape.
00:00:00 2147MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 2 on mesh group79Shape.
00:00:00 2147MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 3 on mesh group79Shape.
00:00:00 2147MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 13 at vertex 0 on mesh group79Shape.
00:00:00 2148MB | [mtoa] RGBA attribute file9.defaultColor has no alpha component: exporting as RGBA
00:00:00 2149MB | [mtoa] RGBA attribute file2.defaultColor has no alpha component: exporting as RGBA
00:00:00 2151MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file30.defaultColor has no alpha component: exporting as RGBA
00:00:00 2151MB | [mtoa] RGBA attribute file17.defaultColor has no alpha component: exporting as RGBA
00:00:00 2151MB | [mtoa] RGBA attribute file18.defaultColor has no alpha component: exporting as RGBA
00:00:00 2151MB | [mtoa] RGBA attribute pasted__file5.defaultColor has no alpha component: exporting as RGBA
00:00:00 2152MB | [mtoa] RGBA attribute pasted__file18.defaultColor has no alpha component: exporting as RGBA
00:00:00 2155MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file20.defaultColor has no alpha component: exporting as RGBA
00:00:00 2155MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file21.defaultColor has no alpha component: exporting as RGBA
00:00:00 2155MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file3.defaultColor has no alpha component: exporting as RGBA
00:00:00 2158MB | [mtoa] RGBA attribute file4.defaultColor has no alpha component: exporting as RGBA
00:00:00 2158MB | [mtoa] RGBA attribute file10.defaultColor has no alpha component: exporting as RGBA
00:00:00 2159MB | [mtoa] RGBA attribute file3.defaultColor has no alpha component: exporting as RGBA
00:00:00 2160MB | [mtoa] RGBA attribute file8.defaultColor has no alpha component: exporting as RGBA
00:00:00 2161MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file23.defaultColor has no alpha component: exporting as RGBA
00:00:01 2162MB | [mtoa] RGBA attribute pasted__file25.defaultColor has no alpha component: exporting as RGBA
00:00:01 2162MB | [mtoa] RGBA attribute file6.defaultColor has no alpha component: exporting as RGBA
00:00:01 2163MB | [mtoa] RGBA attribute pasted__file23.defaultColor has no alpha component: exporting as RGBA
00:00:01 2245MB | [color_manager_syncolor] synColor version 2018.0.80
00:00:01 2245MB | [color_manager_syncolor] native catolog directory: C:/Program Files/Autodesk/Maya2020/synColor
00:00:01 2245MB | [color_manager_syncolor] optional custom catalog directory: C:/Users/carte/Documents/maya/synColor/Shared/
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Groundcover.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/hw bg newtransparent.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/hw bg newtransparent_ALPHA.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Body-DM8192_u0_v0.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/RedBrickBuilding1.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/FenceUV.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Tongue-TM_u0_v0.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/MoreBuilding.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Teeth-TM_u0_v0.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Body-Spec_u0_v0.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_wall3.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Spines-TM_u0_v0.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_wall2.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_wall1.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/FencePostUV.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/RoofUV.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/TreeLeaves.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/TreeBark.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/MonsterHouseUV.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/TreeLeavesAlpha.tx"
00:00:01 2246MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_concrete1.tx"
00:00:01 2254MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Eyes-TM_u0_v0.tx"
00:00:01 2256MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Bricks.tx"
00:00:01 2257MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Le Road.tx"
00:00:01 2265MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Church Textures.tx"
00:00:01 2268MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Eyes_mem-TM_u0_v0.tx"
00:00:01 2270MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Body-TM_u0_v0.tx"
00:00:01 2270MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/52c51e8f930c5376b85421b7bc9786e9.tx"
00:00:01 2245MB |
00:00:02 2253MB | [gpu] setting OptiX disk cache location to: C:\Users\carte\AppData\Local/NVIDIA/OptixCache/arnold-6.0.2.0_driver-445.87
00:00:02 2314MB | GPU 0: GeForce RTX 2070 enabled
00:00:02 2314MB | [color_manager] using color manager of type "color_manager_syncolor"
00:00:02 2317MB | [color_manager] rendering color space is "scene-linear Rec 709/sRGB" with declared chromaticities:
00:00:02 2317MB | r(0.6400, 0.3300) g(0.3000, 0.6000) b(0.1500, 0.0600) and w(0.3127, 0.3290)
00:00:02 2313MB |
00:00:02 2313MB | there are 1 light and 2001 objects:
00:00:02 2313MB | 3 persp_camera
00:00:02 2313MB | 1 ortho_camera
00:00:02 2313MB | 1 skydome_light
00:00:02 2313MB | 36 image
00:00:02 2313MB | 1 utility
00:00:02 2313MB | 19 lambert
00:00:02 2313MB | 18 standard_surface
00:00:02 2313MB | 1 color_correct
00:00:02 2313MB | 1 complement
00:00:02 2313MB | 1 range
00:00:02 2313MB | 1 driver_exr
00:00:02 2313MB | 1 gaussian_filter
00:00:02 2313MB | 2000 polymesh
00:00:02 2313MB | 1 list_aggregate
00:00:02 2313MB | 1 color_manager_syncolor
00:00:02 2313MB | 1 renderview_display
00:00:02 2313MB |
00:00:02 2313MB | rendering image at 960 x 540, 3 AA samples
00:00:02 2313MB | AA samples max <disabled>
00:00:02 2313MB | AA sample clamp <disabled>
00:00:02 2313MB | diffuse samples 2 / depth 1
00:00:02 2313MB | specular samples 2 / depth 1
00:00:02 2313MB | transmission samples 2 / depth 8
00:00:02 2313MB | volume indirect <disabled by depth>
00:00:02 2313MB | total depth 10
00:00:02 2313MB | bssrdf samples 2
00:00:02 2313MB | transparency depth 10
00:00:02 2313MB | initializing 2088 nodes ...
00:00:02 2313MB WARNING | /group87/POV/POVShape: ignoring scaling component in camera matrix
00:00:02 2337MB | creating root object list ...
00:00:02 2337MB | node initialization done in 0:00.01 (multithreaded)
00:00:02 2337MB | updating 2089 nodes ...
00:00:02 2352MB | scene bounds: (-3478.05713 -84.1937561 -3332.56396) -> (3349.84033 848.516846 4843.41113)
00:00:02 2352MB | node update done in 0:00.06 (multithreaded)
00:00:02 2352MB | [gpu] preparing 2089 nodes ...
00:00:03 2425MB | [gpu] updating 2089 nodes ...
00:00:06 2652MB | [skydome_light] /aiSkyDomeLight2/aiSkyDomeLightShape2: 1000x1000 importance map done in 0:02.23, average energy 0.468460
00:00:07 2671MB | [aov] parsing 2 output statements ...
00:00:07 2671MB | [aov] registered driver: "defaultArnoldDisplayDriver@renderview_display" (renderview_display)
00:00:07 2671MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter@gaussian_filter" (gaussian_filter)
00:00:07 2671MB | [aov] registered driver: "defaultArnoldDriver@driver_exr.RGBA" (driver_exr)
00:00:07 2671MB | [aov] done preparing 2 AOVs for 2 outputs to 2 drivers (0 deep AOVs)
00:00:07 2707MB | starting render ...
00:00:07 2728MB | [gpu] building scene and compiling shaders ...
00:00:08 2837MB | [gpu] building scene and compiling shaders done in 0:01.261
00:00:10 3833MB ERROR | [gpu] an error happened during rendering : Insufficient device memory
00:00:11 2781MB | [driver_exr] writing file `D:/Images/Arnold_Render_1.1.exr'
00:00:11 2760MB | render done
00:00:11 2735MB |
00:00:11 2735MB | releasing resources
00:00:11 2635MB | Arnold shutdown
00:00:00 2571MB | log started Tue May 12 15:20:30 2020
00:00:00 2571MB | Arnold 6.0.2.0 [46703ee7] windows icc-17.0.2 oiio-2.1.4 osl-1.11.0 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.5.0 2020/02/12 19:28:33
00:00:00 2571MB | host application: MtoA 4.0.2 46d4a92e (master) Maya 2020
00:00:00 2571MB | running on DESKTOP-KIAFN60, pid=9648
00:00:00 2571MB | 1 x Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz (8 cores, 8 logical) with 16315MB
00:00:00 2571MB | NVIDIA driver version 445.87 (Optix 60700)
00:00:00 2571MB | GPU 0: GeForce RTX 2070 @ 1620MHz (compute 7.5) with 8192MB (3211MB available) (NVLink:0)
00:00:00 2571MB |
00:00:00 2571MB | soft limit for open files raised from 2048 to 2048
00:00:00 2571MB |
00:00:00 2571MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2020/shaders ...
00:00:00 2571MB | loading plugins from C:/Program Files/Autodesk/Arnold/maya2020/procedurals ...
00:00:00 2571MB | loaded 121 plugins from 9 lib(s) in 0:00.00
00:00:00 2571MB | loading plugins from C:\Program Files\Autodesk\Arnold\maya2020\bin\..\plugins ...
00:00:00 2571MB | loaded 6 plugins from 4 lib(s) in 0:00.08
00:00:00 2571MB WARNING | unable to create log file D:/Error Log/info.2.*: Invalid argument
00:00:00 2571MB | loading plugin: C:/Program Files/Autodesk/Bifrost/Maya2020/2.0.5.0/bifrost/arnold-6.0.0.0/arnold_bifrost.dll ...
00:00:00 2571MB | loaded 9 plugins from 1 lib(s) in 0:00.00
00:00:00 2573MB | [mtoa] RGBA attribute pasted__file11.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute pasted__file20.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute pasted__file15.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute pasted__file26.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute pasted__file27.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute pasted__file28.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file24.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute pasted__file14.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute file12.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute file13.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute file14.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute pasted__pasted__file1.defaultColor has no alpha component: exporting as RGBA
00:00:00 2573MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file28.defaultColor has no alpha component: exporting as RGBA
00:00:00 2574MB | [mtoa] RGBA attribute pasted__file17.defaultColor has no alpha component: exporting as RGBA
00:00:00 2574MB | [mtoa] RGBA attribute file11.defaultColor has no alpha component: exporting as RGBA
00:00:00 2574MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file26.defaultColor has no alpha component: exporting as RGBA
00:00:00 2574MB | [mtoa] RGBA attribute pasted__file24.defaultColor has no alpha component: exporting as RGBA
00:00:00 2574MB | [mtoa] RGBA attribute pasted__file19.defaultColor has no alpha component: exporting as RGBA
00:00:00 2574MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 0 on mesh group79Shape.
00:00:00 2574MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 1 on mesh group79Shape.
00:00:00 2574MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 2 on mesh group79Shape.
00:00:00 2574MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 11 at vertex 3 on mesh group79Shape.
00:00:00 2574MB WARNING | [MtoA] No uv coordinate exists for uv set map1 at polygon 13 at vertex 0 on mesh group79Shape.
00:00:00 2575MB | [mtoa] RGBA attribute file9.defaultColor has no alpha component: exporting as RGBA
00:00:00 2576MB | [mtoa] RGBA attribute file2.defaultColor has no alpha component: exporting as RGBA
00:00:00 2577MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file30.defaultColor has no alpha component: exporting as RGBA
00:00:00 2577MB | [mtoa] RGBA attribute file17.defaultColor has no alpha component: exporting as RGBA
00:00:00 2577MB | [mtoa] RGBA attribute file18.defaultColor has no alpha component: exporting as RGBA
00:00:00 2577MB | [mtoa] RGBA attribute pasted__file5.defaultColor has no alpha component: exporting as RGBA
00:00:00 2578MB | [mtoa] RGBA attribute pasted__file18.defaultColor has no alpha component: exporting as RGBA
00:00:00 2581MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file20.defaultColor has no alpha component: exporting as RGBA
00:00:00 2581MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file21.defaultColor has no alpha component: exporting as RGBA
00:00:00 2581MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file3.defaultColor has no alpha component: exporting as RGBA
00:00:00 2584MB | [mtoa] RGBA attribute file4.defaultColor has no alpha component: exporting as RGBA
00:00:00 2584MB | [mtoa] RGBA attribute file10.defaultColor has no alpha component: exporting as RGBA
00:00:00 2585MB | [mtoa] RGBA attribute file3.defaultColor has no alpha component: exporting as RGBA
00:00:00 2585MB | [mtoa] RGBA attribute file8.defaultColor has no alpha component: exporting as RGBA
00:00:00 2586MB | [mtoa] RGBA attribute DinoAnimation8:DinoAnimation:DinoAnimation:Irex_rig_blinn_v3d2:file23.defaultColor has no alpha component: exporting as RGBA
00:00:01 2587MB | [mtoa] RGBA attribute pasted__file25.defaultColor has no alpha component: exporting as RGBA
00:00:01 2587MB | [mtoa] RGBA attribute file6.defaultColor has no alpha component: exporting as RGBA
00:00:01 2588MB | [mtoa] RGBA attribute pasted__file23.defaultColor has no alpha component: exporting as RGBA
00:00:01 2558MB | [color_manager_syncolor] synColor version 2018.0.80
00:00:01 2558MB | [color_manager_syncolor] native catolog directory: C:/Program Files/Autodesk/Maya2020/synColor
00:00:01 2558MB | [color_manager_syncolor] optional custom catalog directory: C:/Users/carte/Documents/maya/synColor/Shared/
00:00:01 2559MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Groundcover.tx"
00:00:01 2559MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/hw bg newtransparent.tx"
00:00:01 2559MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Body-DM8192_u0_v0.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/hw bg newtransparent_ALPHA.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/FenceUV.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/RedBrickBuilding1.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Tongue-TM_u0_v0.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/MoreBuilding.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Teeth-TM_u0_v0.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Body-Spec_u0_v0.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_wall3.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Spines-TM_u0_v0.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_wall2.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_wall1.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/FencePostUV.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/RoofUV.tx"
00:00:01 2560MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/TreeLeaves.tx"
00:00:01 2561MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/MonsterHouseUV.tx"
00:00:01 2561MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/TreeBark.tx"
00:00:01 2561MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/TreeLeavesAlpha.tx"
00:00:01 2561MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Carter_concrete1.tx"
00:00:01 2567MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Bricks.tx"
00:00:01 2569MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Eyes-TM_u0_v0.tx"
00:00:01 2571MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Le Road.tx"
00:00:01 2579MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/Church Textures.tx"
00:00:01 2583MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Body-TM_u0_v0.tx"
00:00:01 2585MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/Dinosaur Animation/DinoAnimation_WithTextures/sourceimages/Eyes_mem-TM_u0_v0.tx"
00:00:01 2585MB | [AiMakeTx] maketx: no update required for "C:/Users/carte/Creative Cloud Files/Production Computer Animation/GroupProject/sourceimages/52c51e8f930c5376b85421b7bc9786e9.tx"
00:00:01 2560MB |
00:00:01 2561MB | [gpu] setting OptiX disk cache location to: C:\Users\carte\AppData\Local/NVIDIA/OptixCache/arnold-6.0.2.0_driver-445.87
00:00:01 2565MB | GPU 0: GeForce RTX 2070 enabled
00:00:01 2565MB | [color_manager] using color manager of type "color_manager_syncolor"
00:00:01 2565MB | [color_manager] rendering color space is "scene-linear Rec 709/sRGB" with declared chromaticities:
00:00:01 2565MB | r(0.6400, 0.3300) g(0.3000, 0.6000) b(0.1500, 0.0600) and w(0.3127, 0.3290)
00:00:01 2587MB |
00:00:01 2587MB | there are 1 light and 2001 objects:
00:00:01 2587MB | 3 persp_camera
00:00:01 2587MB | 1 ortho_camera
00:00:01 2587MB | 1 skydome_light
00:00:01 2587MB | 36 image
00:00:01 2587MB | 1 utility
00:00:01 2587MB | 19 lambert
00:00:01 2587MB | 18 standard_surface
00:00:01 2587MB | 1 color_correct
00:00:01 2587MB | 1 complement
00:00:01 2587MB | 1 range
00:00:01 2587MB | 1 driver_exr
00:00:01 2587MB | 1 gaussian_filter
00:00:01 2587MB | 2000 polymesh
00:00:01 2587MB | 1 list_aggregate
00:00:01 2587MB | 1 color_manager_syncolor
00:00:01 2587MB | 1 renderview_display
00:00:01 2587MB |
00:00:01 2587MB | rendering image at 960 x 540, 3 AA samples
00:00:01 2587MB | AA samples max <disabled>
00:00:01 2587MB | AA sample clamp <disabled>
00:00:01 2587MB | diffuse samples 2 / depth 1
00:00:01 2587MB | specular samples 2 / depth 1
00:00:01 2587MB | transmission samples 2 / depth 8
00:00:01 2587MB | volume indirect <disabled by depth>
00:00:01 2587MB | total depth 10
00:00:01 2587MB | bssrdf samples 2
00:00:01 2587MB | transparency depth 10
00:00:01 2587MB | initializing 2088 nodes ...
00:00:01 2609MB | creating root object list ...
00:00:01 2609MB | node initialization done in 0:00.01 (multithreaded)
00:00:01 2609MB | updating 2089 nodes ...
00:00:01 2624MB | scene bounds: (-3478.05713 -84.1937561 -3332.56396) -> (3349.84033 848.516846 4843.41113)
00:00:01 2624MB | node update done in 0:00.05 (multithreaded)
00:00:01 2624MB | [gpu] preparing 2089 nodes ...
00:00:02 2691MB | [gpu] updating 2089 nodes ...
00:00:06 2822MB | [skydome_light] /aiSkyDomeLight2/aiSkyDomeLightShape2: 1000x1000 importance map done in 0:02.91, average energy 0.468460
00:00:06 2838MB | [aov] parsing 2 output statements ...
00:00:06 2838MB | [aov] registered driver: "defaultArnoldDriver@driver_exr.RGBA" (driver_exr)
00:00:06 2838MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter@gaussian_filter" (gaussian_filter)
00:00:06 2838MB | [aov] registered driver: "defaultArnoldDisplayDriver@renderview_display" (renderview_display)
00:00:06 2838MB | [aov] done preparing 2 AOVs for 2 outputs to 2 drivers (0 deep AOVs)
00:00:06 2857MB | starting render ...
00:00:06 2861MB ERROR | [gpu] an error happened during rendering : Invalid value
00:00:10 3142MB ERROR | signal caught: error C0000005 -- access violation
* Arnold 6.0.2.0 [46703ee7] windows icc-17.0.2 oiio-2.1.4 osl-1.11.0 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.5.0 2020/02/12 19:28:33
* CRASHED in optixQueryFunctionTable at 00:00:00
* signal caught: error C0000005 -- access violation
* backtrace:
* 0 0x00007ff90c56302e [ai ]
* 1 0x00007ff90c5622cf [ai ]
* 2 0x00007ff9746a6ffc [KERNELBASE ] UnhandledExceptionFilter
* 3 0x00007ff977bd820b [ntdll ] memset
* 4 0x00007ff977bbfd56 [ntdll ] _C_specific_handler
* 5 0x00007ff977bd479f [ntdll ] _chkstk
* 6 0x00007ff977b34bef [ntdll ] RtlWalkFrameChain
* 7 0x00007ff977bd350e [ntdll ] KiUserExceptionDispatcher
>> 8 0x00007ff8ff403bc3 [nvoptix ] optixQueryFunctionTable
* 9 0x00007ff8ff3f6591 [nvoptix ] optixQueryFunctionTable
* 10 0x00007ff8fed08ace [nvoptix ] optixQueryFunctionTable
* 11 0x00007ff8fecef201 [nvoptix ] optixQueryFunctionTable
* 12 0x00007ff8fed1ee8e [nvoptix ] optixQueryFunctionTable
* 13 0x00007ff8fed1cdf2 [nvoptix ] optixQueryFunctionTable
* 14 0x00007ff8fed376a2 [nvoptix ] optixQueryFunctionTable
* 15 0x00007ff8ff3b58d7 [nvoptix ] optixQueryFunctionTable
* 16 0x00007ff8ff39d0e3 [nvoptix ] optixQueryFunctionTable
* 17 0x00007ff8feae7680 [nvoptix ] optixQueryFunctionTable
* 18 0x00007ff8fea6b0c9 [nvoptix ] optixQueryFunctionTable
* 19 0x00007ff90c3aad92 [ai ] AiNodeSetInt
* 20 0x00007ff90c54c7e8 [ai ] AiNodeSetVec
* 21 0x00007ff960b81030 [VCRUNTIME140]
* 22 0x00007ff960b83338 [VCRUNTIME140] is_exception_typeof
* 23 0x00007ff977bd3ce6 [ntdll ] RtlCaptureContext
* 24 0x00007ff90c54b4c5 [ai ] AiNodeSetVec
* 25 0x00007ff90c574580 [ai ]
* 26 0x00007ff90c3a7dbf [ai ] AiVolumeSampleFltFunc
* 27 0x00007ff90c5b06c7 [ai ] AiRenderRemoveInteractiveOutput
* 28 0x00007ff90c5b0339 [ai ] AiRenderRemoveInteractiveOutput
* 29 0x00007ff90c2cf005 [ai ] AiRender
* 30 0x00007ff911f64d2f [mtoa_api ] CRenderSession::InteractiveRenderThread
* 31 0x00007ff973cc1ffa [ucrtbase ] o_exp
* 32 0x00007ff975a27974 [KERNEL32 ] BaseThreadInitThunk
* 33 0x00007ff977b9a271 [ntdll ] RtlUserThreadStart
* loaded modules:
* 0x00007ff90c1d0000 ai
* 0x00007ff974620000 KERNELBASE
* 0x00007ff977b30000 ntdll
* 0x00007ff8fe690000 nvoptix
* 0x00007ff960b80000 VCRUNTIME140
* 0x00007ff911f10000 mtoa_api
* 0x00007ff973ca0000 ucrtbase
* 0x00007ff975a10000 KERNEL32
Stack trace:
ntdll.dll!RtlWalkFrameChain
ntdll.dll!KiUserExceptionDispatcher
nvoptix.dll!optixQueryFunctionTable
ai.dll!AiNodeSetInt
ai.dll!AiNodeSetVec
VCRUNTIME140.dll!<7FF960B81030>
VCRUNTIME140.dll!_is_exception_typeof
ntdll.dll!RtlCaptureContext
ai.dll!AiNodeSetVec
ai.dll!AiCreateAtStringData_private
ai.dll!AiVolumeSampleFltFunc
ai.dll!AiRenderRemoveInteractiveOutput
ai.dll!AiRender
mtoa_api.dll!CRenderSession::InteractiveRenderThread
ucrtbase.dll!_o_exp
KERNEL32.DLL!BaseThreadInitThunk
ntdll.dll!RtlUserThreadStart
00007FF93183F600
Message 12 of 16
cartscal
Below are two logs, first log is rending one frame and the second is rendering 5 frames. Render settings were set back to default for these tests apart from changing render to GPU. Arnold Render preview also does not work with GPU. CPU works fine for Arnold preview as well as render sequence button. GPU fails both.
BELOW IS RENDER OF ONE FRAME
00:00:00 3089MB |
00:00:00 3089MB |
00:00:01 3043MB |
00:00:01 3067MB |
00:00:01 3067MB |
00:00:05 3341MB |
BELOW IS RENDER OF 5 FRAMES
00:00:00 2362MB |
00:00:00 2362MB |
00:00:00 2362MB |
00:00:00 2138MB |
00:00:00 2138MB |
00:00:01 2245MB |
00:00:02 2313MB |
00:00:02 2313MB |
00:00:11 2735MB |
00:00:00 2571MB |
00:00:00 2571MB |
00:00:01 2560MB |
00:00:01 2587MB |
00:00:01 2587MB |
* backtrace:
* loaded modules:
Stack trace:
ai.dll!AiNodeSetInt
ai.dll!AiNodeSetVec
ai.dll!AiNodeSetVec
ai.dll!AiRender
ucrtbase.dll!_o_exp
00007FF93183F600
Message 13 of 16
cartscal
Unfortunately I've replied with my log a couple of times but I believe it is being removed by an automated spam filter. I'm not sure how I can avoid this.
Best Regards,
Carter
Message 14 of 16
cartscal
Error Log From One Frame Render
00:00:00 3089MB |
00:00:00 3089MB |
00:00:01 3043MB |
00:00:01 3067MB |
00:00:01 3067MB |
00:00:05 3341MB |
Message 15 of 16
cartscal
Error Log from 5 Frame Render
00:00:00 2362MB |
00:00:00 2362MB |
00:00:00 2362MB |
00:00:00 2138MB |
00:00:00 2138MB |
00:00:01 2245MB |
00:00:02 2313MB |
00:00:02 2313MB |
00:00:11 2735MB |
00:00:00 2571MB |
00:00:00 2571MB |
00:00:01 2560MB |
00:00:01 2587MB |
00:00:01 2587MB |
* backtrace:
* loaded modules:
Stack trace:
ai.dll!AiNodeSetInt
ai.dll!AiNodeSetVec
ai.dll!AiNodeSetVec
ai.dll!AiRender
ucrtbase.dll!_o_exp
00007FF93183F600
Message 16 of 16
syndicate5
I wonder if we could have an option in Arnold where we don't post our full render logs in the forums. Maybe only as an attachment instead.
https://www.instagram.com/bumblebee_3d/
