Announcements
Arnold for Maya refuses to install in some computers
Hello:
I have installed Maya (Version 2019.2) in 5 computers, at work and home. Some are running Windows 10, some Windows 7.
In two of them, I have repeatedly removed and reinstalled Maya. I select Arnold (and Substance) to be installed. However in those machines, Arnold is never installed. I am getting the following messages every time I start the application:
// untitled //
commandPort -securityWarning -name commandportDefault;
onSetCurrentLayout "Maya Classic";
// Warning: file: C:\Users\Ramon\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\Ramon\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\Ramon\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\Ramon\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'. //
// AbcExport v1.0 using Alembic 1.7.5 (built Feb  6 2018 18:28:08)
// AbcImport v1.0 using Alembic 1.7.5 (built Feb  6 2018 18:28:08)
updateRendererUI;
// Warning: file: C:/Program Files/Autodesk/Maya2019/scripts/others/supportRenderers.mel line 67: The renderer "arnold" used by this scene, is not currently available. The "mayaSoftware" renderer will be used instead. To prevent this message from being displayed in the future, set the environment variable: MAYA_NO_WARNING_FOR_MISSING_DEFAULT_RENDERER=1 //
Please help.
TIA
-Ramon
Stephen.Blair
That usually means only that the MtoA plugin is not loaded.
What happens if you open the Plug-in Manager? Is MtoA listed? What happens if you load it?
// Stephen Blair
// Arnold Renderer Support
Fixed. I went into:
Windows | Settings/Preferences | Plug-in Manager
It seems that for some reason, in some computers the "Auto load" option is not selected by default.
Thanks!
-Ramon
