Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Archive scene error
4 REPLIES 4
td97720
1391 Views, 4 Replies
Archive scene error
Hey everyone,
I've been having an issue archiving my scene. In the past I have been able to export my scene just fine but now I have this error pop up after my scene saves before zipping the file
# Error: line 0: TypeError: file C:/Program Files/Autodesk/Maya2022\Python37\lib\ntpath.py line 526: _getfullpathname: path should be string, bytes or os.PathLike, not NoneType
Here's a screenshot of the error
https://prnt.sc/1r64wtt
Have any of you run into this issue or have a workaround for this?
Just to note, I copied a previous environment scene on top of my character. Could having the source files for the environment in a different project folder than the current on be causing the issue?
Thanks in advance!
Labels (3)
4 REPLIES 4
Connor_Dang
in reply to: td97720
Did you found the solution yet?
i just got the same issues
td97720
I think it has something to do with volumetrics in a scene. I optimized my scene to get rid of any unnecessary nodes first and that seemed to fix the issue. Keep in mind that if you have volumetrics in your scene that you will need to turn it back on and adjust your settings. I hope this helps!
justey
OMG this is truly helped, thanks!
brendanDWMZM
I was having the EXACT same issue but I didn't have anything special in my scene.. (no volumetrics).  However, I went through and did an 'Optimize Scene Size' (under File) and tried to do as rigorous of a job as I could cleaning up unused nodes, etc., and I was able to FINALLY get Archive scene to work.
I know this is a late reply, but since this was the first thing that popped up for me [on Google anyhow] for this error, I thought I'd contribute since this seems like a problem since Maya 2019 or so.  I'm using Maya 2020.1 now, and Maya really should catch this error with a dialogue of "Too many Broken nodes, Optimize Scene First" [or whatever] - just something so it doesn't feel like all hope is lost with the red-error-of-death on the lower right hand side 😉
