Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Applied Texture Appears Pixelated
7 REPLIES 7
Message 1 of 8
jenna_hines
1295 Views, 7 Replies
I'm in need of help with something. I have textures applied but they look pixelated and I don't know what to do. Any help would be greatly appreciated.
This was not created by me and I found this from a website. I'm just using this for learning purposes.
7 REPLIES 7
Message 2 of 8
mspeer
in reply to: jenna_hines
Hi!
Please make sure that in the file node Filter Type is not set to "Off" .
Besides this it could be a problem related to your GPU and driver settings.
It should not matter if the Viewport shows moiré, as long as the final rendered output does not.
Message 3 of 8
jenna_hines
in reply to: mspeer
I double checked the file node Filter Type and none of them are set to "Off", so it's most likely my GPU and driver settings. Any suggestions on what I should do?
Message 4 of 8
n8skow
The moire patterns you are seeing are typically due to the filtering setting of the image files. There's a few different options to choose from in the file node.
Message 5 of 8
mspeer
Hi!
Please provide the scene-file and a 1:1 sized screenshot.
Message 6 of 8
jenna_hines
in reply to: mspeer
Here's the scene file.
Message 7 of 8
damaggio
I knew this was the problem....You don't have a single UV map for anything, why not take a Maya class instead of trying to learn alone a complex software or at least some texturing tutorials on Youtube?
Also next time upload the scene first so we don't need to guess and waste time.
Cheers.
Message 8 of 8
mspeer
Hi!
There are some UVs on the objects, but they are totally corrupted.
Please create a proper UV mapping for every object in the scene.
