Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Alpha Gain on Image Plane is not functioning Maya 2023
5 REPLIES 5
mayanim8
420 Views, 5 Replies
This may be a bug, however, I would like some confirmation.
System being used:
Windows 10
Graphics Card: GeForce RTX 2080
Clean install Maya 2023
Default Preferences
The Alpha Gain setting on the Image Plane no longer appears to be functioning.
When a JPG or PNG is uploaded, the Alpha Gain merely turns the image off when the value goes below 0.05.
The value of the image is not affected until then.
Is this a bug or is there some new setting or node that is required to get this affect.
5 REPLIES 5
mcginnc
in reply to: mayanim8
Hi sorry for the delay. I tested with both a jpg and a png in 2022 and 2023 and the Alpha Gain is working correctly. Is this still a problem? If so, perhaps there's a setting on the imagePlaneShape node that you didn't notice. Does this happen with all jpgs and pngs? Thanks, Catherine
Catherine McGinnis
Maya Quality Assurance
glenhintz2551
ralpha gain onlyalpha gain onlyalpha and color gain combinedalpha and color gain combined
The only way I can get Maya 2023 and 2024 to adjust the transparency (alpha gain) of a png or jpg image plane is to adjust both the alpha gain and color gain in the attribute editor.  In all previous versions I could adjust the alpha gain in the channel box or input values and have the transparency respond.
damaggio
in reply to: glenhintz2551
Still works here in 2023 just adjusting the Alpha Gain slider, I have not used 2024 yet.
jbobe03
I am having the same issue, any new work arounds for this problem?
damaggio
in reply to: jbobe03
Update your version to Maya 2023.3.
