Announcements
All Materials Are Missing
kaan.aslanturk
kaan.aslanturk
  As you can see all textures connected. Everything must be fine but I am constantly getting this error. I dont know how many times I had to recover a previous save and redo again. When it fist happen I tought it is a saving error but no it is not.
Matterials resets to base ones like a new project. I have no idea why it happens. It is not project setting error or something like that. It sometimes happens and sometimes not. I have search  on internet for this kind of error but couldn't find anything like that.
damaggio
you saved your file with modeling history and then  you reopened.
kaan.aslanturk
I dont think it is because of that. I try to delete all history ofen because of performance issues. And when the problem accours it effect every save I make. Doesn't change if I delete history or not. Alsocit effects autosaves. Sometimes autosave is fine and sometimes like that. and when this happens, every save. saveAs, autosave effects. But othertimes bouth autosave and other saves are fine. As I sad I heve no idea why it happens. Also wheen it happens there is no way to know until closing and reopening.
Beside all as I sad it just effects all materials. And it doesnt matter if I make any modelling or not.
damaggio
You seem to be working in mb instead of .ma, make sure you understand the differences.
Please upload one of you files here for someone to check.
kaan.aslanturk
Can file type can  be cause of problem. I dont think I changed the default one. I make a research for what that means and as I understand one of them is text based file and otherr is not. I gues mine .mb is not text based one.
Because of file sizes are too big I am uploading to drive. Here is the link. MuseumIlerlemeBackUp is last save that I have uncorrupte. SergiSalonu is problematic one. Even tho I dont upload full project because of it is even way bigger, materials should be exist without texture files. My problem is disepearing matewrials afterall. So I hope it gives enought material to undeerstand what is wrong with my file.
https://drive.google.com/drive/folders/1-vpN9WWGajo-wgm_ojxdyjHU_bQuhTzq?usp=sharing
I am replying now but it may not uploaded yet. Even After zip. it is about 1.3 gb.
