When attempting to open Maya, it bounces on the dock briefly and immediately stops opening, identically to how this troubleshooting page describes. However, none of the solutions were helpful. When opening through the Terminal, the output gives the error "ADLSDK_STATUS_LICENSE_CHECKOUT_ERROR". I've tried doing a clean install of the program, deleting all Autodesk-related files from my computer, but this did not help. The licensing software is up to date and running.
When running the command "sudo /Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper list" as I found on this page, it only returned ARNOL, but not Maya. So this means that my system does not recognize Maya as being registered if I understand correctly. My question is, how do I "register" Maya on versions 2020+, or at least, how do I get Maya to recognize that it is? Because whatever automatic process it uses does not seem to be working as intended on my computer. If anyone knows of a manual way to register Maya 2020+, it would be greatly appreciated.
The version of MacOS I'm currently using is 10.14.6.
I am using a student license and I've gone through the entire student verification process successfully.
The Terminal output and log file are attached.
I have already looked at the links below, neither of which provided a working solution:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/When-you-...
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/A-licensi...
Apologies if I've made any formatting errors or anything, this is my first time on the Maya forums. I hope that one of you is knowledgeable enough to know the solution, because I've been banging my head against the wall about this for weeks now. Cheers.
