AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Adding a polygon to mesh
I'm trying to add a polygon to a mesh, where only one edge of the polygon is exist in the mesh (only 2 points of the polygon are already exist in the mesh). I tried to use the "addPolygon" function, but it didn't worked because the mesh doesn't contain all the points of the polygon.
Does anyone know how to add such a polygon to the mesh?
J450NP13
You could just create the polygon with a plane and then combine it and merge the vertices you need to be merged.
but how can I combine the plane with the mesh (what functions combine them together)?
J450NP13
Select both objects and then goto Mesh>Combine.
Then select the vertices and go to Mesh Edit>Merge
The mesh is represented as a MFnMesh object in cpp code and the polygon is represented as an array of MPoint objects in cpp code too , and I'm trying to merge them in code. Do you know how can I do that?
J450NP13
No I don’t off hand.
