Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Accidently cropped ratio of default perspective, trying to undo
4 REPLIES 4
chriswilloughby210
140 Views, 4 Replies
I accidentally cropped my perspective camera to 640x480.
I haven't been able to undo it.
If anyone can tell how to undo it I'd be super appreciative.
Thanks for your time,
Chris
4 REPLIES 4
Cropped? Accidentally?
Go to RenderSettings > ImageSize section where you can find a bunch of standard res presets, or enter your own sizes.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Thanks for your help. Maybe I wasn't clear enough, the cropping is in the live viewport of the perspective camera. It's not a render setting of the image. In the jpeg I attached it shows a screenshot of the problem.
Peace.
Yes, arrow in your image points to the 640x480, so I thought you are referring to the resolution.
Anyways, this kind of "cropping" happens every time for the viewport panel in such aspect ratio. Once you switch AttrEd/Chanbox visibility, the aspect decreases and resolution gate scales down. Perhaps, you can decrease its size relative to the panel in camShape > DisplayOptions > Overscan.. set it to smth like 1.500.
,,,_°(O__O)°_,,,
Thanks for the help. The problem was in display options. Somehow I had checked on Display Film Gate, Resolution and Gate mask. I must have somehow hit a hot key combination that clicked them on. Unchecking them solved the problem. have a good one. 🙂
