A way to target weld by whole loop to another loop
soswow
soswow
See this scene. There are two objects (separate shells).
They have two loops each. I want to weld every two corresponding edges together. And what is important, I want to
edges of a bottom object to weld into edges of a top one.
See from the side:
You can see top object has bottom edges all ligned up. Basically I don't want them to in the middle.
the only way I can see right now is to combine two shells and then do target weld one edge at a time.
Christoph_Schaedl
Use bridge and ring collapse.
https://linktr.ee/cg_oglu
soswow
I tried googling and using the search function inside Maya itself. Mind explaining what "ring collapse" is?
Christoph_Schaedl
Its in the edge marking menu on the top.
Christoph_Schaedl
Made a video.
You need to combine the objects first.
https://youtu.be/lV022fqLN0Y
soswow
Right. Thank you for recording a demo!
Thought I specifically said
> And what is important, I want to edges of a bottom object to weld into edges of a top one.
It would be even better if I said top edge loop should come does and merge with corresponding edges of a bottom edge loop. Imagine that that jagged form of bottom edge loop is an important one. I knew how to merge them "in the middle", hence asked that question.
Christoph_Schaedl
In that case. Bridge, slide edge and merge.
