4K image - Maya
4K image - Maya
manoj_imagevfx
Observer Observer
Message 1 of 8
4K image - Maya
manoj_imagevfx
Observer
Observer
4K image appears squeezed in camera image plane, image is created in photoshop 4k DCI format
This post has been edited due to: @heather_tracy added the product to the title to help more community members find this topic.
Replies (7)
Message 2 of 8
Christoph_Schaedl
Could you exlain the issue further? i have no idea whats the problem.
https://linktr.ee/cg_oglu
Message 3 of 8
heather_tracy
Hello @manoj_imagevfx
Thank you for posting your question in the community.
Kindly provide additional information about your issue, including [product name], [product version], and a [detailed issue summary], including error messages or a description of commands leading to the issue. You can also embed screenshots or attach a screencast recording to allow the community to assist further.
Looking forward to hearing back from you with more information so we, as a community, can help you!
All the best,
Heather | Community Manager
Message 4 of 8
damaggio
A 4k “square” image resolution needs to match your image plane size settings as well as your render settings , you need to match the pixel size ratio, that’s why is squeezed.
  • Adjust "Fit" setting: Select the image plane, open the Attribute Editor, go to the "Placement" tab, and try setting "Fit" to "Size". If that doesn't work, try "Best".
if is not for a still image a square format is not suitable for film/animation work.
Message 5 of 8
manoj_imagevfx
Observer
Observer
Thanks for the response.
I created a reference image for my matte painting workflow in Photoshop
using the 4k DCI 2160p document preset. However, when I import this same
image into the camera image plane of the Maya 2026 trial version, it
appears squeezed and does not match the original aspect ratio.
Please see attached files for the same
Message 6 of 8
manoj_imagevfx
Observer
Observer
Message 7 of 8
manoj_imagevfx
Observer
Observer
Message 8 of 8
manoj_imagevfx
Observer
Observer
