Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
2022.3 Crash when opening a scene
7 REPLIES 7
Message 1 of 8
grendizerus
584 Views, 7 Replies
Hello I use Maya 2022.3 on Windows 10, GPU is Intel HD Graphics 530.
After Maya starts, I try to open  a scene. Some scenes do open, others cause Maya to crash.
Here is my latest crash log :
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal write at address 0x6056BCD0
Fault address: 6056BCD0 in C:\Program Files\Autodesk\Maya2022\bin\maya.exe
0000:3CF747B1 Logical offset (see .map file for location)
Call stack:
End of stack
//crash log file name = C:\Users\david\AppData\Local\Temp\MayaCrashLog211224.1557.log
//version = 22.3.0.981
//cut = 10/27/2021, 202110272215
//current scene = unDisclosed
//command history (most recent last):
//last tool: renderWindowSelectContextItem
//panel with focus: modelPanel4
//visible panels:
// modelPanel4 outlinerPanel1
//Memory usage:
// 1113.137 Mb Free Memory
// 4575.188 Mb Free Swap
// 1842.961 Mb Current
7 REPLIES 7
Message 2 of 8
damaggio
in reply to: grendizerus
No scene attached.
Message 3 of 8
grendizerus
This one of the scenes that crash Maya
Message 4 of 8
lui3d
do you still having this issue because after this new update 2022.3 Maya crashes on rendering gpu or when I'm working any type of modelling.  No even the crash report comes out,  I didn't have any issues before 😞 ..did any one back to you! cheers!!
Message 5 of 8
grendizerus
Yes I still have that issue.
Have you checked your temp folder to see if an error report appears?
Message 6 of 8
frankino
Hi
I'm experiencing this issue as well recently.
I mostly use xgen for grooming, so everytime I save a scene (re-opened from the crash file) I can only work on that, then save. If I reopen the scene the day after, my scene will crash again, then the only thing I can do is open the crash file.
Is there any fix on this Issue?
I:m still using maya 2022.3, and to be honest I cant switch on maya 2023.
Any help?
Thanks for your time.
F
Message 7 of 8
grendizerus
For me the problem was VRAY. I had to uninstall VRAY.
Message 8 of 8
lui3d
in reply to: frankino
go back to 2022 don't update, see if it works.
