Xgen Guides Spinning around itself
Deepterra
Deepterra
Hi everyone,
I have a problem in maya xgen process. When I create xgen guides on mesh, guides spinning it self. Guides turning causes each hair to rotate. I was removed maya and delete preferences and re install but it didnt solved. Mesh has uv map and deleted history. Mesh normal is seem correct.
I believe you can help me overcome the solution. Thank you in advance.
Replies (0)
