Maya Dynamics
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya dynamics topics.
XGen Groomable Splines error HELP PLEASE!!!
2 REPLIES 2
1326 Views, 2 Replies
Hello everyone.
I'm using Maya 2018 Student Version.
I'm very new to hair dynamics. I started exploring the XGen to create fur for my character. I tried using Groomable Splines and wanted to export the grooming (I mean the yellow lines on the pink grid) to import it to another .ma file later. But I messed something up with the saving/exporting directories at the section on the screenshot attached. As I remember, I browsed for a new path for Export parameter but there's a slight chance I accidently did it for XUV. The path contained non-latin letters.
After that I got this line:
# Error: line 1: UnicodeEncodeError: file C:\Program Files\Autodesk\Maya2018\plug-ins\xgen\scripts\xgenm\xmaya\xgmExternalAPI.py line 1390: ascii
This shows up at almost every move I do on the fur.
Since then, when I edit the file where it all happened or create a new file and try grooming with the Groomable Splines, the error still shows up. Plus I can't see the Settings and Log sections in Grooming tab any more (although the brushes such as Part, Smooth, Orient etc are still there). I can't edit the density or average length of the yellow-pink lines but still can groom them with brushes. But primitives don't follow them at all.
After a while I realised the issue might be in the path with non-latin letters and changed the name of the folder to English but this didn't help either.
Sorry for the poor explanation, I really am extremely new to this and don't know proper appellations of all the stuff yet.
So my question is what have I done to my programm? Does anybody know a solution for this error? That would be a pity to brake down my XGen before even getting to know how to properly use it, LOL
Any suggestions ASAP please!!!
2 REPLIES 2
cavescholar
So I know Xgen can be fun to learn and also complicated sometimes. I might suggest that you set a project and use the default folder for the Xgen saves. The error could be the plugin not loading correctly, you can try unchecking the xgen plugin, restart Maya, then re-enable the plugin. Maybe that will help. For Xgen saves and load locations and other information I've included a link to the article.
Here is an article from Autodesk Knowledge Network on Where does xgen load and save files? The following is a clip from that article.
"As an alternative to a Project Folder, an absolute path can be assigned to a given location. You can add multiple paths if need be:
Autodesk Knowledge Network Xgen File PathAutodesk Knowledge Network Xgen File Path"
There are a few more tips on that page hopefully that helps.
Good Luck!
in reply to: cavescholar
Thank you for a quick answer!
I've reset my maya prefs a few days ago and it resolved the problem. But the article you attached helped me understand better the overall structure of collection and descriptions paths, I apreciate your time!
Technology Administrators
