Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
XGEN doesn't create Archives
scratchkaboom
scratchkaboom
Hi everyone!
I hope somebody could help me. It's my first time with XGEN.
Every time I try to export a mesh to an Archive (.xarc) I just get the folders and a 'log' file, all of them with the same issues, but xgen file/s.
I tested following some steps from this forum such as 'disabling auto-save', loading Arnold before export, re-loading some plug-ins, saving the scene before creating a description, checking the paths, and everything looks fine. But I can't export anything using 'Maya 2018.1' .
Any idea? Thanks in advance!
This is the 'log' file I get:
pymel.core : INFO : Updating pymel with pre-loaded plugins: renderSetup
Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/initialStartup.mel line 179: Y-axis is already the Up-axis
Initialized VP2.0 renderer {
  Version : 2016.11.35.12. Feature Level 5.
  Adapter : AMD Radeon (TM) R9 390 Series
  Vendor ID: 4098. Device ID : *****
  Driver : .
  API : OpenGL V.4.5.
  Max texture size : 16384 * 16384.
  Max tex coords : 32
  Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
  Shader compiler profile : (Best card profile)
  Active stereo support available : 0
  GPU Memory Limit : 4095 MB.
  CPU Memory Limit: 31032.4 MB.
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
 0: Advanced Micro Devices, Inc.. AMD Accelerated Parallel Processing. OpenCL 2.0 AMD-APP (2482.5).
 Supported extensions: cl_khr_icd cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_amd_event_callback cl_amd_offline_devices
OpenCL evaluator choosing OpenCL platform Advanced Micro Devices, Inc..
OpenCL evaluator is unable to find a GPU device that can share VBOs with OpenGL.
Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/autoLoadPlugin.mel line 35: Loading plug-in "lookdevKit" has resulted in changes to the scene that may need to be saved.
Warning: file: C:\Users\******\Documents\maya\2018\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'.
Warning: file: C:\Users\******\Documents\maya\2018\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'.
Warning: file: C:\Users\******\Documents\maya\2018\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'.
Warning: file: C:\Users\******\Documents\maya\2018\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'.
AbcExport v1.0 using Alembic 1.5.8 (built Jul 13 2016 18:28:45)
QWidget: Cannot create a QWidget without QApplication
scratchkaboom
And this is the internal Xgen Log:
