When I use one to modifier clump on my description (interactive grooming description).
The effect of to modifier is good took into account in the viewport, and I see the changes.
When I launch a render with arnold, I have the following message:
- // Error: [curves] procedural_A98ECFCD1E5B2F57_curves: invalid number of points (found 0, expected 6825676) //
The render is not made, I do not understand.
Can use me?
Ps: I am on Maya 2017 update 3
Thank you
If you have an example scene you can share, that would be helpful to diagnose the issue.
Have you tried re-installing Arnold in the meantime?
Cheers
We've fixed the underlying issue internally but it's not yet in a released version. There is a workaround though and it's to add a cut modifier. The cut values can be very low so as to not change the look too much but this will allow the render to work.
Cheers
