XGen AnimWires - Primitves show weird behavior
philippfarmer
philippfarmer
I'm currently working on a horse animation and I use xgen for the tale and mane hair. I use AnimWires to simulate the hair with a nhair system. The nhair simulation looks great, exactly the way I want it to. But when i attach the curves and run the simulation with the xgen primitives preview, the primitives go completly crazy (see videos). I've googled a lot and tried everything I could find, but nothing worked for me. The result is always the same. I hope someone knows this problem and knows how to fix it.
philippfarmer
For those interested... I didn't find a solution to the problem, but I found a way around it that gives me more or less the same result I was hoping to get with AnimWires. I simply used guide animation under the preview tab. The preocess is basically the same - you create nhair and attach it. The nhair then controls the guides. Now that I know this feature I dont really get the point of having the AnimWire modifiere at all. But I'm no xgen expert neither so it doesn't really matter whether I get it or not.
