Problems in creating pouring water by using Bifrost
Hello, maya fellows. I try to create water pouring out of a bucket by using Bifrost. But some problems stand in my way. First, I selected my emitter then created liquid in Bifrost option. A very very tiny cubic appeared in the center of grid. It seemed the tiny liquid container would never cover the emitter. Second, I continued to select an object for colide. Warning appeared ' xx has a large area and may run out of memory or take a while to simulate'. Then, I ignored it and continued to make animation, nothing happened.
I wonder if it is because of my geometric size of my models or something else? And I tried create new scene and simple model to test Bifrost, everyting worked well.
agraham
Your scene scale looks pretty massive. How many units across is your bucket? Your MVS could be too low. The default of 0.5 is too low-res for objects this small, try reducing it.
As for your collider issues, what objects are you colliding with? If you selected the ground, it looks huge; that's why you're getting those warnings. Try creating lower-resolution proxies for your collision geometry, and use those as colliders. Make sure they only extend to where you want the liquid to go, and no further.
Adrian Graham
Principal User Experience Designer
ME Film and TV Solutions
Thank you for your tips, Agraham. I scale down my scene to real world geometry, right now the bucket is around 30 cm. As a result, no more such warnings. In the end, liquid has been created. However I still have a question for you maya guru. When I selected the object inside bucket, created liquid, then selected bucket and gravel pile as collider, ran animation, I found no liquid being created. But after imported an bifrost example named "milkpour", ran animation again, liquid being created. I don't know if it's because I messed up some settings when I imported previous models. What's your opinion?
Are you using SP4? Because I'm getting the same warning about memory that I never got before. The no liquid being created issue your having, I have had also. I corrected it being quitting Maya and restarting it. But it's still unusable for me. Its so slooooooowww.
I even made a new scene, made an emitter out of a small box colliding with a plane and I was amazed how slow it was. I really hope its just a bug because I loved using Bifrost it used to be so fast.
I have noticed the plug-in is very touchy and can stop working altogether for no good reason and Maya needs to be restarted.
Hi, there. Yes, I am using maya2016SP4, too. For the memory issue, I fixed it by rescaling down the whole scene. And for the no-liquid one, I had tried two times. In the first time I imported a bifrost example in Bifrost 'get Example' option, then my model began to have fluid. In the second time I created bifrost cache in Bifrost 'Compute and cache to disk' option, then it started to create liquid. I hope it works for you too!
