Problem with the boss editor
Lately i've got an issue with the maya boss editor. When I open up a file in maya and add the boss wave solvers everything works fine, but once I close the boss editors window with the close button I can't open it back up. It than gives me an error on line 167 unicode there is no attribute node.
I've tried deleting all my presets, re-installed maya, but still have the same issues.
Ive tried the following
- Deleting all presets
- Re-install
- Saving the file and opening it back up
- Importing the file in a new scene
- Saving it as a ma.
I kept having this issue. Once I close the window once in the file the scene is damaged and i'm not able to use the boss editor again.
What can I do to solve this issue.
best regards
Danilo
Grahame_Fuller
Hi  Danilo,
This is a bug that has been fixed. You can download the latest version of Bifrost for your version of Maya from the Download Center.
To workaround the issue without updating Bifrost, open the Boss Editor in a new scene and then open your saved scene.
I hope that helps,
gray
Grahame Fuller
Learning Content Developer
I am having the same problem using the latest version of Bifrost
Grahame_Fuller
Do you get an error message in Maya's script editor? What does it say?
Cheers,
gray
Grahame Fuller
amolina10QDP8C
Community Visitor
Community Visitor
This actually helped! THank you!
