Point to Surface Not Creating a Constraint
Good morning all,
I've tried in vain for hours to research this, even going so far as to download a different version of Maya (from 2018 to 2016) in case it was a bug, but no luck! I'm hoping this will be a simple fix and I'm missing something obvious, and your help would be very much appreciated!
Basically, I am unable to create a Point to Surface constraint. I select the vertices of the cloth object (I've tried this in both vertex and component selection mode, not sure if this makes a difference?), shift+clicked the object I want to bind it to, and hit Point to Surface. The console reads "// Result:" and nothing happens - no constraint is created in Outliner, and the cloth object just drops. The only constraint I've been able to make successfully has been a Transform Constraint, presumably because this only requires vertices from one object?
Hope that makes sense - I'd really appreciate any advice you could give me! Thanks!
