Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Maya Dynamics
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya dynamics topics.
nHair detaching when i animate the model?
0 REPLIES 0
Message 1 of 1
275 Views, 0 Replies
Forgive me if the answer is simple but this problem torments me for days.
I have a problem with the nHair, in particular when i create eyebrows and eyelashes with a brush of Paint effect.
I summarize below for clarity:
- Create the eyelashes or a strand of hair from a brush "paint effect"
- Convert paint effect to curves
- I select curves and polygon on which to attack the hair
- "Make selected curves dynamic" (attack curves and curves are checked)
at this time, when I do the tests of the simulation, if I try to move the character or animate the character, the hair move, BUT detach from the surface, as if he had a different pivot point. Only manually bringing the character behind the hair will meet again with the surface, but as soon as I move the vertices that also influence the follicles or character ...hair begin to give the same error.
The UV map is correct. For testing I also created a new project as in the picture, an object, one curve, to minimize the error but the problem remains!
while if I use the curves made by hand from the EP curves tool, the problem does not arise!
I can not create hundreds of lines manually so complex, as a brush of paint effects!
Do you have solutions?
0 REPLIES 0
