Announcements
New to Mash. How to edit UVs on Mash strength Map?
directorBHHWT
directorBHHWT
I am new to Mash and using a simple mash (mesh) network with grid distribution and a texture plugged into my strength map to generate a dotted earth map effect. As you can see in my image, the texture in my strength map is distorted and I do not know how to go about editing the UVs. Any advice would be appreciated.
directorBHHWT
I figured it out 😀 You have to create a separate mesh with your desired UVs and connect it to the strength map's helper. I learnt what to do here https://vimeo.com/164069048 There were some minor adjustments I had to make to the workflow, because in this video they are using Maya 2016.
