nCloth Simulation Wont Enable
b00375640
b00375640
I have no idea how to fix this problem. Basically I have a uni task to add dynamics to a kitchen scene. I used nCloth on some curtains and it worked fine. I unchecked the enable box on the cloth so I could work on some other dynamics with the intention of enabling it before rendering.
Now I check enable and nothing happens. The curtain mesh stays static.
Any suggestions would be appreciated. Thank you
DyllanCFX
Here are some questions off top of my mind...
- Is the nucleus on?
- Is there a cache attached to it?  Is the cache static?
- Is the start frame correct?  And have you rewind the time to start frame and play it from there?
