hello. I have been using Maya's ncloth for several weeks now. I will attach a file below where ncloth is working. Recently I started working on another ncloth project. when I applied ncoth materials, when I get to the step of creating a passive collider, Or when I try to play the animation after creating the passive collider, the file crashes right away. I tried a simple scene of a plane with a ball and the ncloth worked fine so I though it might be a setting issue in my file. I reset my settings/preferences, deleted history, created a new pref folder on my computer, and tried copying the same objects from my file into a maya scene that worked, but when I get to the collider step, maya crashes.
So at this point i think it may be an issue with my passive collider object. I tried exporting it as an obj and re-importing but it doesn't help.
I'm not sure what the issue with that mesh is, because it is the same mesh as the one I used in the maya file where ncloth is working...I just cleaned up the materials.
Am attaching the working ncloth scene and the newer nclothscene that crashes. Would appreciate any help.
