I Create ncloth in maya 2022 but it shows like this. how to fix this ?can anyone help me.....?
Message 1 of 9
Replies (8)
Message 2 of 9
DyllanCFX
I'm not sure what the issue here exactly...is the invisible ground plane the problem?
Message 3 of 9
I turned on use plane option in attributes. But n cloth not showing shadow. I dont know what happend..
Message 4 of 9
DyllanCFX
Hmmm, maybe the viewport is set to "Use Flat Lighting"?  If so, you can switch it back by click on Lighting (just above the viewport) > Use Default Lighting.
Message 5 of 9
Its already in default.
Message 6 of 9
mspeer
Hi!
Please provide a scene-file for further help.
Message 7 of 9
here my scene file.
Message 8 of 9
DyllanCFX
Hi @Anonymous
I checked out your scene and I still don't see it.  Maybe try to rename the "prefs" folder and relaunch Maya, then try it again?  This will be my last suggestion.  If it still doesn't work, then I'm not sure what it is.
Message 9 of 9
mspeer
Hi!
This is a bug in Maya 2022. There is an evaluation (update) issue related to the normals of nCloth objects.
The solutions are:
a) Enable Cached Playback.
b) Update to Maya 2022.3 or higher where this has been fixed.
