Maya Dynamics
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya dynamics topics.
Fluid emitter ground shadow problem
1 REPLY 1
ColtonHodge
259 Views, 1 Reply
Hey guys, I'm a 3rd year vfx student working on a portfolio submission, I'm having an issue with getting a fluid shadow to render on the ground plane of this scene, I'd really appreciate any help, thank you,
Colton
1 REPLY 1
MayaGuru
in reply to: ColtonHodge
Hello Colton,
May I know which render you are using now.If you are dealing with Mental ray then you are required to use ray-trace shadows and make sure in the render setup the shadow type segments must be clicked.You are also required to use a shader which is "use-Background".This will allows you to create only shadows for your scene.
