I can't really determine what is actually happening with this issue but as best i can tell when I disable and re-enable the nucleus node it causes a massive slowdown in the UI and all operations in Maya, input text into fileds, playback, opening windows - everything except navigating the viewport is virtually unusable.
Restarting Maya has no affect. Maya remains in this hobbled state until I reboot the machine and everything goes back to normal, until I need to disable the nucleus again.
Any guesses as to what is causing this?
2017 update 4
Hi!
No problem here on windows.
Your animation settings, Evaluation Mode "DG"?
I'm not sure what that means.
I stripped everything out of the file that wasn't necessary and it still happens. I think it may be the nCloth constraints.
