Announcements
Create an explosion in Maya?
AlaaAliTaha
AlaaAliTaha
Is it possible to create an explosion in maya and convert it to any other common format (fbx) to be used in another cg software ... any ideas ?
yes-change voxel representation in fluid & convert it onto mesh
syracoj
for nParticles you could use the dynExport python command to output pdb/pda's.
for maya fluids, you could use a technique similar to this one:
http://technophobiax.blogspot.ca/2014/01/maya-fluids-to-particles-krakatoa-my-23.html
to get maya fluids transfered to nParticles (I personally have never tried this)
and then use dynExport to output pdb/pda's
if your using bifrost Aero you could use the bif2prt devkit example to export your sim to prt files (to send to Krakatoa)
the dynExport w/ example can be found in the maya help doc: Under Technical Documentation > Python Commands
