Cloth Problem
Cloth Problem
Cloth Problem
I am trying to create a curtain using nCloth. I created two rings, made holes in the curtain using Boolean difference, deleted the history, made the rings Passive Colliders and made the curtain nCloth and when I play the animation the curtain looks like it is torn, and falls down like in the pictures.
Any help?
Thank You!
mspeer
Hi!
1. Check your mesh, enable Solver Display "Collision Thickness, maybe you need to correct (e.g. triangulate) your mesh first.
2. Change values for your nCloth attributes or choose an other preset.
3. A nConstraint may better fit your needs, try it.
