Regardless of what I try maya is not letting me paint soft body weights.
https://www.youtube.com/watch?v=_oeTb6fk4AE
Solved by mspeer. Go to Solution.
Hi dude . i did the same process as you, and works fine. Im using maya 2017 update 2.
Really dont know what´s the problem, are you in viewport 2.0 ?
Hi!
With an Opacity value of 0 it will not paint or generate (Flood) anything.
Set Brush -> Opacity to a value higher than 0.
