Maya Dynamics
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya dynamics topics.
Can't find Bifrost > Convert User Cache to PRT or bif2prt.bat
29 REPLIES 29
Message 1 of 30
gnarlog
2229 Views, 29 Replies
Hi there,
I'm new to bifrost, so I don't really know what I'm doing, but in the docs there is mention of the bifrost option:
and a batch file called
bif2prt.bat
Both of them are supposed to convert .bif files to .prt
There is no Convert User Cache to PRT in my bifrost menu, and there is no
bif2prt.bat anywhere on my system. Am I missing something?
Also, in the compute and cache do disk options, it doesn't matter what cache format I select, it always writes .bif files.
Anyone know what's going on with this?
Matt
29 REPLIES 29
Message 21 of 30
thebenp
in reply to: agraham
Thanks again for taking the time to look into this.
Looks as though the issue I was having was with the latest version of partio on github, switched back to the last stable release and it looks as though it can process these PRTs just fine.
Sorry for the goose chase.
To recap, the whole point of figuring this out was to free up the bifrost caches to be rendered in other renderers or even brought back into Maya as a normal particle cache, and thus take advantage of the particle system features. Haven't tested everything yet, but at least viewing and converting these PRTs seems to be working now.
Very cool Cat Happy
Thanks Adrian.
Message 22 of 30
Scott_Kero
in reply to: thebenp
Can you send me a copy of the script you use for sequences and what program you are running it in? New to scripting. Thanks. -Scott
Message 23 of 30
agraham
in reply to: Scott_Kero
Sorry, you mean for converting sequences?
Everything is explained in this blog post:
http://area.autodesk.com/blogs/valhalla/converting-bif-files-to-prt
Adrian Graham
Principal User Experience Designer
ME Film and TV Solutions
Message 24 of 30
olyspinks
HI,
Can anyone help
I'm having some trouble converting Foam .bif to .prt with the Maya 2017 update 2. I'm using
Set PATH=%PATH%;C:\Program Files\Autodesk\Maya2017\plug-ins\bifrost\devkit\bif2prt\bin
FOR %i IN (*Foam*) DO bif2prt.bat -f %i
Method and I get bif2prt: Conversion failed
Kind Regards
Oly
Tags (1)
Message 25 of 30
jbusenberg
Hi Adrian,
I tried this and it's giving me bif2prt: file loading error but i was able to do it one file at a time converting .bif to .prt
do you know how to fix it? the frames i'm converting are like 5gb each, would be great to queued them up at the same time instead of waiting around all day...
thank you!
Message 26 of 30
olyspinks
in reply to: jbusenberg
No sorry I'm still trying to find a work around for this. A guy at work develop a bat file that you could just double click and it would convert what ever was in the folder with it but even that doesn't any more. So it is something Autodesk need to fix. Please let me know if you have any luck
Sent from my iPhone
Message 27 of 30
syracoj
in reply to: olyspinks
hey olyspinks,
did you ever overcome this? If not, let me know, and I will take a look. tnx.
Message 28 of 30
olyspinks
in reply to: syracoj
Hi
Unfortunately not if you could look at it that would be awesome for future projects. If there was something in Maya's interface that could convert them would be a dream.
Oly
Sent from my iPhone
Message 29 of 30
olyspinks
Hi Syracoi,
Did you manage to look at this?
Kind Regards
Oly
Message 30 of 30
syracoj
I tried myself and received this error:
bif2prt.exe - System Error
The program can't start because bifrostapi.dll is missing from your computer. Try reinstalling the program to fix this problem.
OK
So I have drawn up a defect to have dev take a look at what is wrong.
