Maya Dynamics
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya dynamics topics.
Bifrost two liquid colours
2 REPLIES 2
andre.grima
1108 Views, 2 Replies
I am trying to create two separate liquids colliding in bifrost. I managed to create two emitters colliding, but bifrost creates only one instance of the liquid and mesh. Can I create separate ones? and have the liquids blending together?
cheers 🙂
Tags (3)
2 REPLIES 2
Hi Andre,
Unfortunately, Bifröst doesn't support two or more separate, interacting fluids yet.
In some situations, a possible workaround is to use different Density values on the emitters, and then use the density channel to control color at render time. However, that might not give you the desired results.
Best,
gray
Grahame Fuller
Learning Content Developer
Hi Gray,
thanks for your help. I will have to refer to using another software then...
Andre
