No, its not set to zero. I tried with both the default setting (0-100) as well as custom timeline (0-250). As I mentioned, the timeline marker (?) does zip through entire timeline instantly and nothing happens.
In fact here's my simple test:
1. Start a new screen (units are centimeters).
2. Create a sphere (default 1 unit).
3. With the sphere still selected, choose Bifrost - Liquid from the main menu.
4. Hit play
No bifrost simulation. Here's the full script editor output if it might be useful.
Thanks for looking into this!
Loading GoZ support...done!
file -f -new;
optionVar -sv colorManagementColorPickerColorSpaceSelection "Rendering Space";
optionVar -iv colorManagementColorPickerColorMgtEnabled 1;
// Warning: file: C:/Program Files/Autodesk/Maya2016/scripts/startup/rememberViewportSettings.mel line 43: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
// untitled //
commandPort -securityWarning -name commandportDefault;
C:/Users/User/Documents/maya/2016/scripts/
C:/Users/User/Documents/maya/2016/prefs/
C:/Users/User/Documents/maya/2016/scripts/mayaTools.txt
// AbcExport v1.0 using Alembic 1.5.4 (built May 8 2014 13:47:10)
// AbcImport v1.0 using Alembic 1.5.4 (built May 8 2014 13:47:10)
// BifrostMain plug-in loaded (built Jun 10 2015 17:50:45)
updateRendererUI;
// Warning: file: C:/Program Files/Autodesk/Maya2016/scripts/others/supportRenderers.mel line 78: The renderer "vray" used by this scene, is not currently available. The Maya Software renderer will be used instead. //
CreatePolygonSphere;
polySphere -r 1 -sx 20 -sy 20 -ax 0 1 0 -cuv 2 -ch 1;
// pSphere1 polySphere1 //
Time: 2015/7/14 20:21:56
Bifrost Container: |bifrostLiquid1|bifrostLiquidContainer1
Frames Submitted: 0
Frames Succeeded: 0
Time: 2015/7/14 20:21:59
Frames Submitted: 0
Frames Succeeded: 0
// Press the ESC key to stop playback.
Time: 2015/7/14 20:22:00
Frames Submitted: 0
Frames Succeeded: 0
Frames Submitted: 0
Frames Succeeded: 0
Frames Submitted: 0
Frames Succeeded: 0
Time: 2015/7/14 20:22:01
Frames Submitted: 0
Frames Succeeded: 0
Frames Submitted: 0
Frames Succeeded: 0
