Maya Dynamics
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya dynamics topics.
Bifrost Crash M207 update2
13 REPLIES 13
Message 1 of 14
floWbeta
878 Views, 13 Replies
I am simulating an ocean with a BOSS plane as a Guide and a boat as a emissionRegion.
After about 100 frames of successfull cache writing Maya throws this error in the Output window and freezes.
  bifrostfluid.dll!Bifrost::MeshVolume::Worker<Bifrost::MeshVolume::Traits<Bifrost::VoxelShape> >::operator=
  tbb.dll!tbb::interface7::internal::task_arena_base::internal_initialize
  tbb.dll!tbb::task_scheduler_init::initialize
  tbb.dll!tbb::internal::thread_sleep_v3
  MSVCR110.dll!_beginthreadex
  MSVCR110.dll!_endthreadex
  KERNEL32.DLL!BaseThreadInitThunk
  ntdll.dll!RtlUserThreadStart
13 REPLIES 13
Message 2 of 14
stamatk
in reply to: floWbeta
Would you be able to package up your scene and attach it so we can test it on our side?
Also, any details about your hardware and OS would be helpful.
Thanks!
Konstantinos Stamatelos
Bifrost FX Product Owner and Designer
Message 3 of 14
floWbeta
in reply to: stamatk
Sorry cant upload the scene due to NDA.
Win 10
Hardware: Core i7 6850K
4 GPUs 2x 1080 plus 2 x 1080Ti
64 GB Ram
Message 4 of 14
floWbeta
Any update or help  on this? This is becoming a showstopper and i really regret not having used Houdini for the Sim.
I already tried it with different MVS settings without succes.
Message 5 of 14
floWbeta
I even cant get any log output while caching. How am I supposed to find any errors in the setup?
Message 6 of 14
wongt
Can you give us some more information with what is in your scene:
  • Are you using the Boss wave solver or spectral wave
  • Did you cache out the Boss mesh
    • You can try exporting this to an alembic file or use the Boss cache workflow
  • Is the emission region boat mesh also used as a collider
    • If so, some particles may be sticking to the surface of the collider causing a spike in memory (this is more prevalent when foam is in the scene)
    • Try using either a lower res mesh as a proxy or a motion field to push out the particles
  • How many particles is your sim generating.  At anytime when sim'ing, is there a spike in particle count.
  • What else is in the scene
If you are able to reproduce the hang with a simpler scene to avoid the NDA and send it our way, that would be helpful.
Message 7 of 14
floWbeta
in reply to: wongt
Thanks for getting back. I am pretty certain that the problem comes from collision geometry. It is a geometry being destructed by the ship (Houdini Sim imported as Alembic and used as collider).
I am using a cached BOSS surface as a Guide using the BOSS cache workflow.
The emission region boat mesh is also a collider. I will later try your suggestion with the motion field to push out particles. But i dont think the boat collider is the problem. I think it is the other collision geo. Beacuse it is very detailed.
Message 8 of 14
stamatk
That's useful information.
Have you isolated the crash to being caused by the destructed collision geometry for sure? If so, here are some more suggestions:
  • If there's foam in the scene, remove it so that is out of the equation.  The collider stickiness issue mentioned is mostly foam related.
If it still crashes without foam:
  • Try the Solid (Robust) voxelization mode for the complex collider (if not already set), see if it makes a difference. You can also try "coarsen interior"
  • The boundary controls for the complex collider can also be useful.  You can enable the boundary and animate it so that the voxelization only occurs around where you need it, i.e. where water is seeded from the guide.  That way you save memory from voxelizing the entire thing the whole time.
On my side, I was able to simulate 130 frames on Windows 10 in Update2 without a crash, so at least we know the basic workflow is not the issue (see image).
I could send you the scene if you like.
Thanks!
Message 9 of 14
floWbeta
Hey, thanks again.
I already tried robust method with cosrsen interior. There is no foam in the scene now. I want to add it later.
Without the destruction collision it simulated without erros beyond the 100 frames as expected.
I am simming right now with higher resolution and some changes. Will let you know if it crashed. I added a Motion field. But maybe it will not help as you said it has mostly to do with foam..
Message 10 of 14
floWbeta
It crashed again. Why is there no logging? Even when using the verbose mode i get almost no info at all!
How is one supposted to work with bifrost in production? My time is running out. I will check if i can upload the collision geo Alembic file for you. Is there a private place to upload?
Message 11 of 14
stamatk
After reproducing your issue and conducting many tests and trying various workarounds I finally narrowed down the cause of the problem:
The Houdini rigid body simulation mesh used as Bifrost collision geometry has several instances of rogue polygons flying out into infinite space.
This creates a volume so large that Bifrost can't compute the voxelization for collision, and so it stalls.
I was able to avoid this issue by cleaning up the Houdini mesh: Frame by frame isolating the rogue polygons and deleting them. After doing this, I could break through the threshold of frames where I was getting the crash (for me it was 108 frames) and the simulation continued as normal, up until the next set of frames where the mesh had not been cleaned.
I recommend optimising your collision mesh for simulation, to allow Bifrost to do its job properly.
Thanks!
Kosta
Message 12 of 14
floWbeta
Hey Costa!
Thank you for looking into this issue. I will check with our Houdini guy and the try again.
Good to have some good support on Bifrost on Autodesk side.
Cheers!
Florian
Message 13 of 14
floWbeta
Hey Costa,
might using the Boundary Control on the colliderProps solve the problem? Did you try that already?
Message 14 of 14
stamatk
Hi Florian,
I did in fact try that but it didn't work. I was baffled by this until I realised our current implementation of boundary works by first looking at the entire geometry and then just keeping whats inside the boundary, instead of just not caring about what's outside the boundary. Because of this, it still fails in this case.
Hopefully we can improve our implementation of this feature to make it more efficient.
Kosta
