Hello everyone
I am working on bifrost to flow water in a pipe, the pipe has a variable diameter so the water should be flowing in a variable velocity according to the diameter
how can I adjust speed while the water flowing on it's path through the pipe
as you can see from the pic the water colliding into the pipe then it fall out I am not sure why exactly but I think it's because has constant speed in a variable diameter.
Thanks in advance
