XGen output to geometry
My problem:
I don't have the Xgen tools to create/output polygons from Xgen primitives.
There should be 3 places where this tool is located:
1    Modify > Convert > Convert XGen Primitives to Polygons
2    Modeling>Generate > Convert XGen Primitives to Polygons
3    XGen Editor>Preview/Output>Output Settings>Operation>Operation to Create Geometry
The plug-ins xgenMR and xgenToolKit and xgenVray are all loaded.
Thanks, Drew
pshwayka
That command was new in Maya 2017. Is that the version you are using?
cornelh
@Anonymous
All good with Maya 2017 update 2.. can you please sent some screen grabs showing you don't have these options.  again, you might be on an earlier Maya version which might not have those options.
I look forward to your reply,  Cheers
