Particles emitting from surface go off course if surface has been modified
docaberle
docaberle
Modifying the geometry of a plane to make more random particle motion causes the particles to be emitted in directions other than the normal's. The video shows it better than I can explain it. I can attach the file if that helps, but I'm hoping the problem is obvious to those who know what they're doing.
mspeer
Hi!
Works fine here.
There seems to be a problem with your mesh, so please upload a scene-file
docaberle
Here's the file
docaberle
I'm thinking it has something to do with how I added extra geometry and don't have quads in certain spots.
mspeer
Hi!
Yes it's because of unregular geometry, it will be deformed in an uneven way and distortion will occur, see normals.
docaberle
So basically, I can't just go adding edges like I did having some polygons be 5 sides instead of having quads everywhere?
Sorry this is what I was trying before. I guess what I really need to do is emit randomly on the top side of the surface and not from the vertices. Didn't think of that till now. I'm sure that's an option that I'll look for right now.
mspeer
Hi!
"...emit randomly on the top side of the surface and not from the vertices".
Who says it's different, have a look at the face normals.
This is not an even surface, so you have to correct this or use a workaround.
